08-16-2019, 10:24 AM - 2 Likes   #1
johnha's Avatar
Test shots from a 645D & SMC 67 500mm f/5.6 with 100% crops
Hi All,
I've had chance to do some testing with a SMC 67 500mm f/5.6 using the Pentax adapter on my D. My first impressions are good with lots of detail and very little CA. These were fairly quick shots using a Uni-Loc 1600 Major tripod, Uni-Loc 30BH ball head and I used the 2 second self timer (which also locks the mirror up). The files were extracted from the camera as a raw DNG, exported to TIFF without any manipulation and then converted to JPEG for uploading.
Subject distances are well over a km away, considering these were the first shots I'm very pleased with them. Rigging it is slow & cumbersome (as expected), but once on the tripod, actually using it is fairly fluid. The shots were taken from two different locations (moving the rig between the two was a bit awkward).
The photos:
Salford Tower blocks from 1.8km (wind farm approx. 25km):
Hotel Football (Old Trafford) from 1.3km:
Edit: Updated the distance to the wind farm to 25km (15.5 miles).
John.
08-16-2019, 12:10 PM   #2
That's not bad for this old 4 element design lens that pre-dated low dispersion glass.
08-16-2019, 12:37 PM   #3
david94903's Avatar
QuoteOriginally posted by desertscape Quote
I have to agree. That's pretty darn impressive. Your presentation of the big picture and the full crops are great. Really tells the story the lens clearly.
08-16-2019, 02:41 PM   #4
The 5 element 400 Takumar is also quite good with low CA and very sharp. The 600 Takumar has serious CA from f/4 to f/8 but is a very useful lens from f/13 to f/45.
09-13-2019, 03:58 AM   #5
johnha's Avatar
Since posting this thread, I was curious about the wind turbines in the background as these are ideal tests for CA (fine structure illuminated against the sky in bright sun). I've re-measured the distance using Google Maps (and located the correct windfarm this time!), this puts them approx. 15.5 miles (25km) away. I've updated the first image to show a wind turbine at 100% and added an abstract of a building much closer which shows very little distortion.
Salford Tower blocks number 2:
The 'Lightbox' development, Salford Quays (one of several similar buildings):
09-13-2019, 02:01 PM   #6
The CA is not all that bad considering that this lens only has a triplet up front and a field flattener at the rear. This lens competes well with the 400 Takumar. Strangely, the 600 Takumar's CA problem is actually improved a bit with the use of a rear converter, probably because the converter is so well corrected for color.
500mm, 500mm f/5.6, 645d, 645d & smc, 645z, camera, f/5.6, medium format, shots, smc, smc 67 500mm, test shots, tripod
Sigma 50-500mm f/4-6.3 EX DG HSM 100% Crops Eric Seavey Pentax SLR Lens Discussion 16 07-27-2013 06:34 AM
Q10 high ISO 100% crops pihe Pentax Q 14 11-13-2012 02:37 AM
Wanted - Acquired: 100-400mm, 100-500mm, 150-500mm or similar K-mount lens GibbyTheMole Sold Items 8 12-03-2009 11:52 AM
Part 2: Sigma 18-50mm f2.8 EX Macro vs Tamron 17-50mm f2.8 - Brick Wall test (CROPS) eva2000 Pentax SLR Lens Discussion 27 12-21-2008 08:43 AM
DA*300 Sample 100% Crops (Some with TCs) channeler Pentax SLR Lens Discussion 29 05-06-2008 03:16 PM
All times are GMT -7. The time now is 02:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
