There is a clear and meaningful distinction that must be noted between
engaging leaf shutter mode and
cocking the shutter - - two different, but essentially related actions.
Engaging the leaf shutter is done by rotating the ring [on the LS lens] to a shutter speed marked;
cocking the leaf shutter is physically pushing the lever down before each exposure. One thing cannot be done without the other, either way.
The FP (camera) shutter must be set to 1/8s; any higher and it will not synchronise. Additionally note that the TTL meter is inoperative when and LS lens is operated in LS mode, nor can mirror lock-up be used.
I do not recommemd leaf shutter lenses for use by beginners with these cameras, because of the lack of clarity and understanding of their modus operandi and precautions in use (e.g. the 165mm LS cannot be used for multiple exposures as for the 90mm because of jamming, in some cases, irrecoverable). I see enough problems like this with Hasselblad users completely unfamiliar with and very often careless with them.
---------- Post added 2nd Jan 2020 at 04:09 PM ----------
Originally posted by Wasp Back in the day, Pentax made a big deal about how much more usable area a 6x7 negative had over a 6x6 negative. But I am still more of a Hasselblad guy as far as MF goes...
A lot of my pics are 6x7, of course! But then I crop to the much-loved, Hasselblad-flavoured 6x6 format for added sexiness!
Yes, you can do wonders with 6x7...
