11-21-2019, 08:23 AM   #1
90mm lens hood tilted... wrong one?
Hi everybody.
Just got a lens hood for my 90 mm (SMC Pentax 67 #8529189). Once screwed at the reasonable maximum, it ends being tilted. My opinion is that it is generation issue: I bought an old lens hood for a more recent lens. Anyone could confirm my guess please, and then tell me which hood should I buy if you know the answer.
Many thanks for your help.
Hubert
IPad Air  Photo
IPad Air  Photo
11-21-2019, 09:01 AM   #2
I don't know this lens or hood, but ideally there should have been some kind of lock ring on the lens hood to attach the hood in the correct position (apparently this wasn't planned for your hood). The different names suggest that the hood was designed for a older Takumar version of this lens, but the length and shape of the hood should be fine for your lens in my opinion. You could try to cut away a tiny bit from the hood until it gets in position.
11-21-2019, 10:02 AM   #3
gofour3's Avatar
QuoteOriginally posted by Hubert Hayaud Quote
Hi everybody.
Hubert
Welcome to the forum!
The 67 90/2.8 uses a plastic clip-on PH-SB67 hood. The hood you have is for the older Takumar leaf-shutter 90mm lens.
Here's one on eBay:
https://www.ebay.com/itm/New-PENTAX-PH-SB67-Lens-Hood-for-67-90mm-f2-8-and-6...-/123915582097
Phil.
11-21-2019, 10:27 AM   #4
Hubert,
If I recall correctly, the metal hood you have should have a very small screw that you can loosen to adjust the final orientation of the hood. I thought it was a small flat head - but it has been a while since I've had that hood on my 105mm (I can see about finding the old hood in the jumble of older 67 gear I have).
Yuri
Hi everybody.
Hubert
11-21-2019, 01:48 PM   #5
QuoteOriginally posted by gofour3 Quote
Here's one on eBay:
New PENTAX PH-SB67 Lens Hood for 67 90mm f2.8 and 67 105mm f2.4 Lens 4961333029365 | eBay
Phil.
Thanks everyone. So I definitly don't have the right one because of a generation issue. Many thanks for your quick and detailed answers.
645d, 645z, 90mm lens hood, camera, hood, lens, medium format
Landscape Tilted sedimentary strata. Terry C Post Your Photos! 4 04-20-2019 02:42 PM
Tilted Tall Ship Back2shoot Monthly Photo Contests 6 05-10-2018 10:05 PM
Tilted Super Tak 50mm F1.4 lens on DSLR? thephototruth Pentax SLR Lens Discussion 19 05-27-2014 06:16 PM
Nature Wrong Lens, Wrong time, Wrong…………. lukulele Post Your Photos! 4 05-08-2014 03:11 AM
Crooked/tilted sensor results in tilted pictures dpowerherndz Pentax K-5 5 09-10-2012 11:29 PM
All times are GMT -7. The time now is 03:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
