Originally posted by mlt Are the film rollers, guide rails and pressure plate completely clean?
As far as I can tell. I've given them a quick wipe just the same.
I'm going to try to be right on the 120 indicator when loading the film and see how that works.
Edit: Just do add, I'm trying to visualize what could cause the entire line to show up on the negative vertically. Since the guide rails are at the top and bottom, I'm inclined to thing it's either an issue with the pressure plate or more likely the rollers. The strange thing thing is that there is no 'pressure' mark on the negative where the line is. If i look at the from the back of the emulsion side, the whole negative is smooth (no indentation for the line). Given that, I'm not sure if it's physical debris making the issue.
