12-10-2019, 10:31 AM   #1
K-mount on 645
Doesn't seem to be any existing system to mount a K-mount lens (35mm image circle) on a 645 camera..
I understand that it won't cover the entire sensor, and also the focus distance is much greater on 645... but even within limited focus range / non-infiinty, etc... I could see it useful to use my fisheye, or 31 limited, or 77 limited on a tilt/shift etc.. on a 645Z sensor. even if it was just as a special effect
I can't be the first person to think this .... has anyone ever jerry-rigged something like this together?
If not, anyone got an old broken lens I can buy the body mount from to experiment?
12-10-2019, 10:48 AM   #2
photoptimist's Avatar
The large difference in mount-to-sensor distances (70.87 mm - 45.46 mm = 25.41mm) has a huge effect on infinity focus, especially for wider-angle lenses.
With a 31mm K-mount lens sitting flush with the 645 mount ring (assuming that is even possible), the focus point with the lens set to infinity would be only a couple of inches in front of the lens. The good news is that at that macro-range distance, the projected circle of the 31 would certainly cover the entire 645 image circle!
A fisheye lens would probably not work at all -- the infinity focus point would be so close, it would be inside the lens.
On the telephoto side, a 300mm K-mount lens would ∞-focus at about 4 meters which might make it OK for less-fearful wildlife.
If you want to play with this at zero cost, just hand-hold whatever lens in front of a 645 camera, look through the viewfinder, and see where it focuses.
12-10-2019, 10:51 AM   #3
bertwert's Avatar
It would be, at minimum if you had no longer extra length to the adaptor, a 25mm extension. This would mean it would only really be suitable for macro, as with a 50mm lens, this would be a max focal distance of 15cm, resulting in a magnification of 1:2.
12-10-2019, 11:15 AM   #4
QuoteOriginally posted by loji Quote
You can use your 31 Limited for macro with the 645 reverse adapter set which happens to be 58mm. You just need an 58mm thread extender, which is available from many Chinese suppliers.
If you want to compose and focus wide open, you'll need the front standard of an auto bellows and use a double cable release.
12-10-2019, 12:19 PM   #5
EssJayEff's Avatar
Do you mean other than the "Pentax Adapter K for 645 Lens?" (I couldn't find it in the Accessories Reviews section, so that link goes to a past Marketplace listing.)
12-10-2019, 12:34 PM   #6
If you couldn't imagine why not before, you know now. I'll add another – to be useful at other than macro range, the lens would have to be sunk into the 645 body. Pentax don't do mirrorless, but you'd probably have a 645 mirrorless after the first release of the shutter. (and a damaged rear element too)
12-10-2019, 12:50 PM   #7
QuoteOriginally posted by StiffLegged Quote
If the P645 cameras had a manual mirror override like the Mamiya M645's, one could certainly use a lens like that with the addition on an external viewfinder. Makes me wonder if there's a 135 format 24mm tilt/shift lens that has enough clearance from the mount in order to be adapted.
12-10-2019, 01:13 PM   #8
MossyRocks's Avatar
QuoteOriginally posted by EssJayEff Quote
Other way around they want to stick a K lens on a 645 camera, not a 645 lens on a K camera.
12-10-2019, 01:20 PM   #9
EssJayEff's Avatar
QuoteOriginally posted by MossyRocks Quote
Ah...got it.
12-10-2019, 08:25 PM   #10
gofour3's Avatar
I've used my Takumar 28/3.5 lens reversed on my Pentax 6x7 for about 5x magnification.
Pentax 6x7 Reverse Adapter 49mm & 67mm reviews - Pentax Camera Accessory Review Database
I'm sure there is a similar adapter for the 645 system.
Phil.
12-12-2019, 09:21 AM   #11
MossyRocks's Avatar
QuoteOriginally posted by gofour3 Quote
How sharp was running it like that? I've done about a 3x with it but anything beyond that I have problems from vibration because I have to do a very long exposure and have kids so everything is blurry.
12-12-2019, 10:39 AM   #12
gofour3's Avatar
I got really good results with the 28/3.5 reversed and using the 6x7 Helicoid extension tube.
There is a picture in my review of the Super Takumar. It's a bead you put on a DIY jewlery:
S-M-C/Super Takumar 28mm F3.5 Reviews - M42 Screwmount Wide-Angle Primes - Pentax Lens Reviews & Lens Database
Phil.
12-12-2019, 01:34 PM - 1 Like   #13
MossyRocks's Avatar
Phil.
well it is good to know that I could go above 3x magnification and still get good results if the kids would quit bouncing around the house so much. With the M42 to 49mm reversing ring, M42->K adapter, a couple of sets of M42 extension tubes and an M42 helicoid I have plenty of gear to use with my 28/3.5
12-12-2019, 04:49 PM   #14
Phil.
Lol, I have that same lens and it's even easier to use with the 645 reverse adapter because they're both 58mm. It's a very cheap and good option for extreme tabletop macro.
12-31-2019, 06:35 PM   #15
It is possible and would have to go mirrorless to make it happen, Such as the gfx. not all lenses work though, some are better then others. The one part that they are able to do, is if they don't completely work, they cut out part of the sensor to turn it into the full frame camera. Also all lenses turn into manual lenses as far as using k mount lenses.
645d, 645z, camera, focus, k-mount, lens, medium format, sensor
645-A 150mm or 645-A 80-160mm jumbleview Pentax Medium Format 8 05-25-2018 03:26 AM
For Sale - Sold: Pentax 645 w/ 55mm, 75mm, 120mm Macro, 150mm and more. FULL 645 Kit! Free shipping gdneil Sold Items 4 04-13-2018 04:42 PM
Pentax Adapter K for 645 Lens (645 to K mount) Read more at: http://www.pentaxforums Uplander Pentax K-1 5 10-05-2016 11:41 AM
All times are GMT -7. The time now is 08:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
