Originally posted by Digitalis At the risk of further veering off topic..
Then don't buy WD desktop USB drives! There are a number of manufacturers such as Verbatim, Seagate, LaCie, Sandisk, Qnap and Samsung make Thunderbolt/USB-C DAS Hard drive chassis that are said to have good reliability and also support hardware RAID, all you need to do is bring your drives to the party.
Although this is a trend these days, there is no reason to dodge wd. Statistics show that they are just as reliable as other brands.
As someone who works in the IT industry you of all people should know, being flat out avoidant about different OS and the tools to recover partitions and data is the opposite of being helpful.
Choosing the correct technology for a specific task is one of the most important things in it, may it be hardware, a dev framework, an OS or a data replication system. Choosing mdadm is like choosing a manual 6×45 camera to shoot thr olympics. It simply fits the purpose that badly it is the wrong choice, although this has been different in the past.
If someone already owns this solution I am glad to help him out, but giving advce to get this solution or to learn it to use it in futire is just bad advice
Unfortunately a lot of these new filesystems have been slow to be implemented due to stability, development time and support costs which also prevent these filing systems from being released in consumer products.
Nothing of this stays true these days. There are plenty fully developed open source solutions available now.
If someone relies purely on RAID to secure their data - they are doing it wrong.
Conveniently, RAID 1 does precisely that. perfect mirror images of the host drive, if one drive fails simply replace it and re-sync. Providing there are enough duplicate drives...say an array of 4 drives in a RAID 1 reduce the chances of catastrophic data loss from a single drive drastically.
About 30% of data loss are due to harddrive failures. So you miss 70% of reasons by uaing any raid in first place.
Raid 1 has no data integrity check at all. If you got broken data on any drive it will be replicated into the new one. In about 20% of cases of a single broken disk in a 3 drive raid 1 there are broken files after recreating redundancy. Raid 1 wears all drives by identical pattern, incresing the chance of mutiple drive failure during raid recovery.
Raid recovery copies smashes data without even noticing, this might even be just some bad inoding which will result in a bad fs and possible loss of information.
The idea that Raid1 provides mutiple copies if the data is simply wrong as any change on data are done simultaniesly on all drives. A faulty ram stick will immidiatly kill your data.
Look at peojects like FreeNas if you dont feel confident setting up next gen fs your own. They provide zfs out of box with checksumming and desaster recovery without spare drives. This enables to check for silwnt data corruption and whipe it out as well as it recognizes bad sectors during recreation of redundancy and chooses another copy instead of copying the faulty one. Still it covers only 30% of data loss, but those at least in 98% instead of 80% of the cases.
