Originally posted by barondla I have Pentax 6x7 equipment. Don't use very often since it is difficult to get transparency film developed anywhere locally. Bought a K-1 6 months ago. Always wondered about a digital medium format.
1. Would it be worthwhile to buy a 645D (can't afford a Z)?
2. Shutter is rated for half the life of APS-C cameras. Can 645D still be repaired?
3. Do 6x7 lens perform well on 645? Is there some kind of "green button" gymnastics involved?
4. Are the FA lenses decent and are they and DFA interchangeable on 645D and 645Z?
5. Do you miss not having live view for critical focusing?
Sorry for all the questions.
Thanks,
barondla
1. Value is something only you can determine. A bigger sensor with more pixels will get you some benefits, notwithstanding the improvements in technology for smaller sensors. This will be especially true at lower ISO values, and therefore for tripod work. But larger cameras are as much about the experience of using them as they are about absolute image quality, which exceed most people’s actual needs in any case.
2. Yes, but probably not quickly or cheaply. These are not spray and pray cameras. Most serious amateurs, if they push the button when they intend instead of just guessing, may not need more than 10,000 actuations in the life of their ownership.
3. Yes. See reviews on this site. Their use on a 645 is seamless when using the Pentax-made adapter, though you will be limited to aperture-priority metering and (of course) manual focus.
4. Yes, the FA lenses are top-shelf professional lenses from a decade or two ago, and they are nearly all excellent. See the reviews on this site. Yes, they operate on the D and Z just as they do on the N and NII. Focus is slower and they are not weatherproof. There is no shake reduction. But pros did without these things and got very sharp images.
5. Occasionally, but not for FA lenses and only rarely for manual-focus lenses. I did find a microprism focus screen for an NII that I put in my Z, which works fine.
Rick “rent one and see what you think” Denney
