01-06-2020, 05:47 AM   #1
Battery for Pentax 6x7
I recently bought an old Pentax 6x7. I'm still on my first roll of film and last time I used it I accidently left on the power so the battery was empty when trying to take a picture just now. I did it anyway just to see what happens (probably should have waited but too late). When taking a photo the mirror stayed up so I guess I just need a new battery? Some wrote this in another thread which I assume is the right way to deal with this problem:
"When a battery is exhausted and the shutter button is pressed, the mirror will rise only half way. At this point, remove the battery and replace with a new one. Then reset the camera by using a toothpick inserted into the recessed button to othe left of the mirror box: press once, then press the shutter and wind on. This is the only correct method to reset the mirror."
I found a couple of 6v batteries online here in Denmark. The measurements they specify look more or less the same as the one in the camera, but just to be sure I posted them below. Are they both the right ones?
4LR44 Camelion 6V Alkaline Plus
GP Batteries GP476A Special-batterier 476 A Alkali-mangan 6 V 105 mAh 1 stk | Conradelektronik.dk
01-06-2020, 06:17 AM   #2
Yes. 4LR44 or equivalent (476A in this case) is the correct one. Or 4SR44 if you're going for silver oxide, which keeps a more stable voltage, doesn't corrode and lasts longer, but also way more expensive.
Never leave a battery inside a camera. That can lead to corrosion and a dead camera.
01-06-2020, 09:28 AM   #3
I used a "PX28" battery in my old 67 body. Hope this helps.
01-06-2020, 09:48 AM   #4
Thanks, it helps a lot. Didn't know that I shouldn't keep the battery in the camera when not using it. I'll remember that.
01-06-2020, 10:14 AM - 1 Like   #5
If the battery ever dies on the road and you cant find a replacement, stack 4 MS76 batteries and wrap transparent tape around them. That's what a px28 has inside. I've used it in a pinch in the 6×7s.
Thanks,
barondla
01-06-2020, 10:23 AM   #6
gofour3's Avatar
I use this battery for my P6x7/67 and they are silver oxide:
Varta PX28 4G13 544 4SR44 6.2 volt Silver Oxide Battery | Freestyle Photographic Supplies
Phil.
01-06-2020, 02:00 PM - 1 Like   #7
QuoteOriginally posted by barondla Quote
Thanks,
barondla
That's good to know, thanks!
QuoteOriginally posted by gofour3 Quote
Phil.
Does it affect the metering when you use a 6,2v instead of a 6v battery?
01-06-2020, 02:01 PM - 1 Like   #8
Silent Street's Avatar
The battery..!?
I forgot about that. Haven't seen or changed mine in the P67 for years and years...
PS: If the camera is the MLU version, tape over the MLU nib before stowing in the pack; there is nothing more infuriating than fetching the camera only to find that somewhere along the way it has bumped itself and conveniently flattened the battery. I do carry a spare (possibly two).
01-06-2020, 03:39 PM   #9
QuoteOriginally posted by Xero Eddie Quote
I don't think that a 6.2 volt battery will affect exposure vs the 6v. The reason is, that if there was a voltage drop during battery use, your exposure would change. This doesn't happen, so a slight voltage variation is not an issue.
01-06-2020, 06:00 PM   #10
Phil.
Interesting. There are no 6v silver oxide batteries in Australia. They are all alkaline, and the two spares I have are alkaline, so it is assumed the extra-extra-long lasting 6v battery in Pentaximus, I is alkaline too.
01-07-2020, 08:03 AM - 1 Like   #11
QuoteOriginally posted by Silent Street Quote
The battery..!?
It's not the MLU version. I got a couple of the batteries and did a reset. The mirror went down so everything is okay again. I'm looking forward to see the first test roll developed. :-)
01-07-2020, 10:42 AM   #12
gofour3's Avatar
QuoteOriginally posted by desertscape Quote
I use the Varta batteries in my 6x7/67 which do not have a metered prism, I use a hand held meter for these cameras. I only use the AE meter in my 67ii, which uses a different type of battery.
The Varta PX-28 silver oxide is available locally in Vancouver and does last quite a long time.
Phil.
645d, 645z, 6x7, batteries, battery, battery for pentax, button, camera, medium format, mirror, pentax, press
For Sale - Sold: Pentax 6x7 300mm F4.0, 6x7 200mm F4.0, 645-A 200mm F4.0 MightyMike Sold Items 58 12-27-2019 12:30 PM
Pentax Medium Format Resources: 645 & 6x7 Cameras and Lenses, 645 & 6x7 Accessories Adam Pentax Medium Format 9 02-12-2017 03:38 AM
Pentax 6x7 Test Without Battery Cereal Killer Pentax Medium Format 7 03-14-2016 01:23 PM
Pentax 6x7 MLU: Battery/Shutter/Mirror Problem. HELP! richard balonglong Pentax Medium Format 7 08-16-2015 12:39 PM
For Sale - Sold: Pentax 6x7 400mm f4 SMC Takumar & 6x7 to K mount adapter littledrawe Sold Items 8 04-30-2012 04:58 PM
All times are GMT -7. The time now is 08:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
