Ah, so! With film loaded, the wind-on accomplished and frame #1 reached, attention can be shifted to the shutter. I assume, too, that the shutter button is unlocked (no offence intended to you but many first-time people overlook this in waves of panic).
Next, see if you can activate the mirror lock-up button, right side of the camera mirror box (viewed from holding the camera position). This swings the mirror up with a quaint "CLOP" sound (to reduce inertia-induced blur by separating mirror slap and shutter travel). Press the shutter button (Bulb or a fast shutter speed, your choice).
If nothing happens, yes, move on to the "toothpick method", better known as the reset procedure! Press the recessed button, press the shutter button and wind-on. That is the reset. I would be concerned if, after this procedure, the shutter button still does not budge.
Note that with the mirror lock-up activated, it is using power from the battery; effectively, it is "waiting" for you to press the shutter. After that, the mirror should return to its normal position and wind-on can be accomplished.
See how you go with this.
