Originally posted by Silent Street Be sure to set the depth of field preview lever to "MAN" when the finder is reading at stopped-down aperture.
This is a reflection of my statement above regarding the use of MAN vs AUTO
There is something else. From reading your last paragraph, it is possible the prism has not been assembled correctly for the coupling pin to line up with the chain, and if this is the cast, it is a red flag to stop at this point.
Remove the prism, then remove the lens. Remount the prism and finally remount the lens. This process will reset the mechanism. Test the camera after this.
Thanks, to clarify are you saying if I stop it down from 2.4 I should put it in to MAN when taking the photo? I guess being new to film cameras I'm having a hard time understanding what the MAN/AUTO is doing in this scenario. I always shoot full manual on my digital cameras, but slightly confused with this. I would prefer to have it in MAN when taking the photo, but it's just not giving me a reading anymore, the meter stays pinned at the top. When the lens is in auto the meter reading changes as the aperture and shutter are adjusted.
I can see that the chain is moving what it is supposed to on the prism (images attached). I've also reassembled this thing like 6 times.
