Originally posted by Ed Hurst With the workaround settings activated, can't you just press the shutter button directly? With 12 seconds, there's probably just enough time for any movement to settle down before the shutter fires. No need, then, for a remote.
Ed, you ask the embarrassing questions :-)
I tested it again and you are right. They key is to switch to mirror up, then press the shutter to trigger the mirror up, then press it again to commence the 12 second count down.
I think when I tested it previously I must have forgotten to switch to mirror up first.
Thanks for the question :-)
