Originally posted by Alex645 it still points to an issue with the aperture either not closing down enough or closing down or sticking closed.
To determine if it's the lens or the camera, trying another lens would probably reveal if it's the zoom lens or the camera.
I put both my 28-45 and 80-160 lenses on and had no issues, so like you said it may be an aperture issue with the lens, which was also my original suspicion (and what I'd hoped for, instead of a camera issue).
---------- Post added 04-09-20 at 10:20 AM ----------
I just compared my 150-300 lens to one that I know has been working normally...
I'm pretty sure it's a sticky aperture because when I stop it down manually using the aperture ring and then move the little lever (or whatever that's called) it opens back up slowly, instead of instantly like my other functioning lens.
Now, the question is...can I get it repaired anywhere? Or does it just need some lubrication and can I do that myself?
