Several threads have discussed the bokeh of lenses in this focal range for the 645. Since I have an interesting selection of lenses in this range, including some that are usually thought to be world-class in the bokeh department, I ran a (sort-of) controlled comparison. This is not that rigorous a test, but maybe it will give an impression of how these lenses render out-of-focus details.
First, some clarity. Bokeh is about the quality of that rendering, not the quantity of it. The longer the lens (if subject distance is preserved), and the wider the aperture, the blurrier those details will be. But that is not bokeh. Bokeh effects fall into several categories:
- Out of focus highlights are rendered with bright edges. This often results from optimizing for apparent sharpness at wide apertures, which has been a hallmark of Japanese lens designs in past years. (And that generalization demonstrates that all generalizations are ultimately false. But the exceptions to it are rare enough to prove the rule).
- Those highlights are rendered with a neutral disk that has a sharp edge but that is not brighter than the rest of the disk.
- Or, the highlights are rendered with a faded edge. This is usually the result of slight (perhaps intentional) undercorrected spherical aberration at wide apertures. (Soft-focus lenses achieve the effect using spherical aberration.)
Other attributes can also be apparent. Sometimes, out-of-focus backgrounds have a swirly effect, where they seem to arrange in a circular pattern around the image center. Bright-edge bokeh may create false detail in the background as fuzzy spots overlap and create aliasing patterns, making it look closer to focus than the details would be without those overlaps. This undermines the smooth transition from sharp to fuzzy with greater distance from the focal plane. That smooth transition is what creates the illusion of three dimensions, and false detail undermines that illusion.
It should be noted that my own preferences lean toward smooth, faded-edge bokeh with smooth transitions. But that is a subjective determination. Others prefer different rendering to achieve their artistic intentions. So, there is no
better or
worse in this comparison. I just observe the effects that I see, and it's up to you to determine what you like, despite the opinions I may express.
The test camera is a 645z, mounted on a Gitzo tripod. The sunny conditions made the tripod unnecessary--even at ISO 100, shutter speeds were quite high at the apertures used in the test. But I wanted to keep the camera aimed to the same focus point between shots, so I used the tripod for convenience.
Here's the lineup:
- Pentax 645 FA 150/2.8 with Pentax shade.
- Pentax 67 200/4 (Pentax adapter) with integral shade (the front element is very deeply recessed). As far as I know, this is the latest design.
- Pentax 645 FA 200/4 with Pentax shade.
- Pentax 645 A 80-160, at 160, with aftermarket rubber shade.
- Pentax 67 165/2.8 (Pentax adapter) with slide-out integral shade.
- Carl Zeiss Jena MC Sonnar 180/2.8 with Hasselblad compendium shade, in Pentacon Six mount with a Hartblei adapter. This is a classic Sonnar design from the 50's that has only been tweaked slightly from the original Olympia Sonnar. This Sonnar design uses the original very thick elements not found in later western Zeiss Sonnars. This lens was made in 1978, probably near the peak of Zeiss Jena quality control, when they were almost up to western standards. This is the later model with multicoating and the stepped barrel, but not from the last few runs that had four and five-digit serial numbers. This is not the sharpest lens I own by any means, but the rendering is what makes it special. It's a fast lens that is most interesting at wide apertures.
(All the arrangement pictures were made using a Canon 5DII.)
Test Setup 1
In this arrangement, the focus target was an iron boot last (which I now realize I forgot to bring back into the house). That was about the only thing I could find that wouldn't move in the breeze, but was tall enough to poke up into view in the bed of daffodils.
All these images were made at f/4, except for the zoom, which only goes to f/4.5.
FA 150
P67 200
FA 200
A 80-160
P67 165
Sonnar 180
I was looking at these, scrolling through them in DxO Photolab, and my wife was looking over my shoulder. She did not know which lens was which, and doesn't know enough about what I was testing to be able to tell based on magnification. But she said, "That's the Sonnar" when it popped up. The rendering is that characteristic, even to a non-techie. The P67 200 was close, and much smoother than the 645 200. The fast 150 was not as nice. The P67 165 had the swirly thing going--again, not my favorite.
Before leaving this setup, I compared the three f/2.8 lenses shot wide open. Here are those images:
FA 150 at f/2.8
P67 165 at f/2.8
Sonnar 180 at f/2.8
The Sonnar is the clear winner here, per my own preferences. Also, it completely lacks longitudinal chromatic aberration which is evident in the two Pentax lenses when viewed at 100%.
Test Setup 2
In this test, I was wondering what a busier background would look like with a longer subject distance. The focus target was my famous River Birch, and my Azaleas in the background are just in the bud stage. The longer distance brought the background closer to the the focus plane with respect to the camera, and this is a bit of a bokeh torture test.
FA 150. Lots of false detail and a busy rendering.
P67 200. Still a bit busy, but much nicer to me.
FA 200. Bright-edge bokeh is visible here, and it's not as nice as the P67 200.
A 80-160. Not all zooms have crispy bokeh, but this one does.
P67 165. Like the P67 200.
Sonnar. Best of this batch, though still not completely smooth with this subject material.
Test Setup 3
These shots are all at f/11, so I'm not looking at out-of-focus rendering, but rather landscape rendering. So, does good bokeh mean bad landscape images, or the reverse? Is there correlation? Let's see.
Here's the setup. The camera is looking past the house to the Dogwood and Japanese Maple trees in the side garden.
Here are the images. I'm not zooming into these--they were all shot at f/11 and were sharp enough even at 100% to be wholly usable even for large prints. I'm more interested in the overall rendering, color, and contrast.
FA 150
P67 200
FA 200
A 80-160 at 160
P67 165
Sonnar
Not a lot of difference here, but the Sonnar is my least favorite of these. Go figure.
Test Setup 4
Back to the front garden and those Daffodils. This time, I was aimed a bit differently to put my Ford Expedition in the background. My intention here is to provide some specular highlights and technically crisp edges to evaluate. The focus point is still that iron boot last.
Images:
FA 150 at f/4
P67 200 at f/4
FA 200 at f/4
A 80-160 at f/4.5
P67 165 at f/4
Sonnar at f/4
No clear winner here, though there are a couple of losers. I think the P67 200 might be the match of the Sonnar, or even edge it out. For bokeh, the P67 200 is clearly a better performer than the FA200 for the 645, though the 645 lens is sharper at optimal aperture and MUCH easier to carry around.
Finally, a series of pictures of the lenses mounted on the camera to get a sense of their bulk. Here's where the Sonnar comes in as the BEAST.
FA 150
P67 200. This is much bulkier than the 645 200, but it's not that heavy.
FA 200. Small, light, sharp at optimal aperture, but NOT a bokeh monster. Most of what you see is lens shade.
A 80-160. A bit beastly, being denser than either 200.
P67 165. Larger and heavier in this older version.
CZJ Sonnar 180. Wider rather than long, and very heavy. The compendium shade is NOT the reason for the weight. This Hasselblad shade is light and excellent. The lens comes with a hard plastic screw-in shade (for the 86mm filter ring), but the compendium shade is much more effective for a lens often used with studio lights.
So, as I have concluded in the past, bokeh is subjective but it's also real. The Sonnar makes a superb portrait lens, and comes closest to the 3D effect we often seek with the use of selective focus. But the P67 200 is no slouch.
Rick "respectfully submitted" Denney
Reason: Typos
