Here is a CZJ 180/2.8 Sonnar on a 645Z--a late model multicoated version but not the latest, dating from the late 70's. Yes, you stop it down for metering and exposing. I use aperture-priority (Av) or manual (with flash or an external meter, but usually Av) and let it set the shutter speed. Or TAv and let it set the ISO.
I never use the green button so I can't answer that.
Focus confirmation works great, but I also have a microprism screen (from an NII) that is accurate, too. I do my focusing wide open.
My adapter was made by DVDTechnik (aka Hartblei, or at least the same bunch of technicians in Kiev) and it's a little fiddly, but as long as I'm attentive not to force things it works fine.
(made with the Sonnar at f/4)
I have a Hasseblad compendium shade mounted on it. The shade uses a 95mm filter ring, but the plastic shade that comes with the Sonnar is mounted on an 86-95 adapter already, so it's an easy application. I set this up for use with studio lights, and the compendium shade is especially effective in that application.
I have lots of lenses in the Pentacon Six mount, but the Sonnar is one of only a few I would consider using with the Pentax. The Arsat Fisheye is another, and maybe, under certain circumstances, the 55mm Arsat PCS shift lens. The Pentax lenses are sharper, but lack the creamy rendering of the Sonnar.
Rick "nothing provides the creamy rendering of that Sonnar" Denney
