Originally posted by barondla Thanks for the tips. Just ordered the screen from your link. Looking forward to having a 645Z, heck any DSLR, with split image focusing. Did you lay the screen on a cloth while cutting the tab off, or use some other technique?
Thanks,
barondla
Barondla, I put on gloves to stop the accidental greasy fingerprint to get into the grounded surface, because it is impossible to clean without damage, a lesson I learned from previous attempts. Then I put a soft cloth on the table and hold the screen so that one edge is on the cloth (table) with the nib closest to the table side. With the box cutter you just start to shave off the nib, a small slice at a time.
Just try to avoid touching the grounded side of the screen because it scratches very easily. The rest is just patience and a steady hand.
