Originally posted by rdeloe I'm not in the UK so can't help you with this project. However, I have the SMC Pentax-A 645 35/3.5 and the HD Pentax-D FA 645 35/3.5, and I've had the FA 645 35/3.5. I also have the 645 45-85 (A) and have had the Pentax 67 45/4. I've only used them on a GFX 50R as tilt-shift lenses if that's relevant.
Anyway, long story short, let me know if you want to buy my HD Pentax-D FA 645 35/3.5.
It's not better than my A as a shift lens in any way that I can measure or replicate. It's not sharper, and it's not better at the edges. The one thing it has going for it is Lightroom has a built-in correction profile (but that profile does a good job on the A too so it's not much of an advantage). The P67 45 is a very nice lens, but it's soft on my 50R once I zoom in. The 45mm end of the 45-85 leaves it for dead on my GFX 50R. I'm not saying you can't make excellent photographs with the P67 45. I know people who do. But if you need sharpness and detail, it comes up short.
You're in a great position to comment - thanks for your input. It's the long story I'm interested in – don't cut it short on our account please!
In my experience, every P645 and 67 optic passes the test of being able to make great pictures with. They're safely among the best MF lenses that aren't Hasseblad. But the 33-55, SMC 35, FA35, D-FA35 differ by design, will have different merits, and are directly comparable. Similarly, the 45-55mm lenses.
This isn't necessarily my experience, but collating received opinion and weighting against outlying data points (ie, from an AI perspective), would folks agree this is the generally-held view of these lenses in 2023, now largely based on their performance on 35mm and GFX? We might expect a shift of opinion since their original reputation was made using different cameras.
35mm
SMC-A: better in outer image circle than FA35; worse flare, similar geometric distortion, similar CA
FA35: slightly sharper in centre circle than SMC-A, especially at wider apertures; worse field curvature
D-FA: better coatings than either (reduced flare), but otherwise similar to FA
33-55mm: peak performance at 33-35mm, but greater distortion. Comparable centre-frame resolution to 35mm primes at f11-16 but weaker outer image circle
45-55mm
67 55/4 (v3): best optically centre frame; excellent bokeh
55/4 (earlier versions): uncertain how they compare with 45mm variants
645 55/2.8: not sharper overall than 645 45-85: some say yes; others no: likely better at wide apertures; perhaps not as good framewide at f8-f11. Busy bokeh.
645 45-85: best optically in outer image circle at 45-55mm (deteriorates with increased focal length); good bokeh, slightly worse distortion
645 45/2.8: uncertain how compares with 67 45/4 (worse than SMC 35/3.5)
67 45/4: uncertain how compares with 645 45/2.8, but larger image circle likely produces better 'corners'. Flare-prone.
Please feel free to revise or contradict this summary . . .
