Loos like you decide to stay with K1. I think this is a wise decision given what you have.
645z is a wonderful camera. It is one of my best investment in astrophotography over perhaps 30 years. However, as others have pointed out, you need a scope with large image circle to do justice to 645z. Not many scopes can do that, and definitely not a GSO. (A heavily retrofitted GSO can, perhaps.) Indeed, even with an FF camera, the GSO may have issues. You will need a good field flattener or large focal reducer on a GSO RC to produce a flat field for an FF camera, and this would required a focuser much better than what GSO offers in its standard package.
For astrophotography without a telescope, 645z is not a perfect choice either. The camera is really excellent in terms of sensor performance, but lenses from Pentax are just not good for astrophotography. (I try to be polite here. So I just say they are "not good.") First of all, the apertures are too small to start with, as you probably had also realized. Then, almost all of them have terrible coma/astigmatism in the corners and require severe stopping down of the aperture. To take really decent pictures, you will need to go to a dark place and integrate for hours to overcome the small aperture+stopping down. I see that you have an equatorial mount. So in principle, you can do that. But that's really not the best thing to do. You will be torturing yourself. Use an FF camera plus a good large-aperture lens (like those from Sigma) and you will be in a much better position to take stunning photos, and this will cost much less.
If you do have a telescope that can cover 645z's sensor well, I would say go for it. You won't regret. For everything else (astrophoto-wise), don't.
You are welcome to check my gallery. There are many 645z astrophotos.
---------- Post added 08-23-20 at 11:43 PM ----------
Originally posted by barondla Thanks for the website. I live in a Bortle 5 area. Driving 5 miles gets me to a Bortle 4. The trade off is I'm no longer on my property.
I have access to a 7" refractor with 2.7" focuser. It should handle the 645Z image circle. Where would I get the proper camera attachment? Might try some astrophotography when work settles down.
Thanks,
barondla
There is at least one off-the-shelf 645z adapter:
M65x1 female thread to Pentax 645 camera mount adapter
All you need now is an adapter with M65x1 thread and whatever attachment required by your 2.7" focuser.
Note that you will also need a field flattener for your refractor. A 7" refractor with a 2.7" focuser should be able to fully illuminate the sensor of 645z, but the stars won't be good in the corners as the focal surface is usually curved. Once you have a flattener, you need to pay attention to its back focus.
