Rob,
For some time I have followed your detailed posts here and in other fora and was inspired to buy several Pentax MF lenses and Fotodiox TLT ROKR tilt/shift adapters, mount them to my Nikon Z7 and see how much useable shift I could extract for my panoramas. In the following example the camera is in landscape orientation and the lens is shifted to left and right.
I will show here some results for the SMC PENTAX-A 645 f/3.5 and would then like to post similar tests for the 45mm f/4 67 lens, the 55mm 6X7 f/4 and the 55mm 67 f/4 lens. Not sure what section to post those in...if someone can advise that would be good
I used a big RRS tripod, geared head, electronic shutter, f/11 in all cases, manual exposure, manual focus, ISO64 and a 2 second timer. I shot two subjects - one about 4oo metres away and another about a kilometre away. I used Lightroom for the raw conversion and made the same tweaks to all images.
For interest, I also shot each subject with the Nikon 24-70 f/4 lens at corresponding focal lengths, to see how well each Pentax compares in the centre of the frame to a modern full format/35mm lens. The Nikon was also shot at f/11, but using autofocus with single point AF area mode. I also have the 24-70 f/2.8 S lens but I did not shoot that in this comparison. It is somewhat better than the f/4 version shown here.
OK, with all that out of the way, I will start by showing the 35mm lens compared to the Nikon against two different subjects. The jetty is the closer subject and the apartment block further away. I will nominate the shots as being from Camera A and Camera B. Feel free to guess which is which. I will post the result in a few days. (Hopefully I stripped all the EXIF from the files!). These are all crops at 100%.
Jetty
Camera A
