Originally posted by n333ms I'm a proud new owner of a Pentax 645 camera. The set up I have is very clean and in excellent condition. Last week I took my first test roll of Kodak Portra 400 and did various shots, however when I recieved my negatives only the first 10 photos showed up on the negative, the following 5 negatives were completley transparent and did not register. The numbers on the edge of the roll came up, however the photos did not. Now I'm just trying to eliminate some of the variables that might have caused this issue. The place I took to develop the film was horrible, (it was my only choice where I am, I usually mail in my film). My first thougt was that the lab might have screwed up, but I'm not positive if that's the case. My other thought was that maybe it was a battery issue in loading to the next exposure, but I feel like that's also unlikely because after the whole role was shot the camera automatically wound the film correctly. The last 5 shots I took, where done indoors at night with +3EF, according to my light meter it should have been ok, but there is the chance that the shots were blown out. I'm not new to film, I'm just new to this camera and want to make sure everything checks out.
Any thoughts?
Congrats on the 645! 120 film is great. There is a learning curve.
Three things point to it NOT being the lab's fault.
1. Some of the photos came out fine.
2. All the info Kodak exposed on the negative edges is fine.
So the film was properly developed thru the whole roll. If the lab had messed up developing part way into the film, the "exposed by Kodak" edge info would be as transparent as the matching images.
3. Bad images are clear. This means light didn’t reach the film. If the lab screwed up and exposed the film to light, the images would be dark.
So the clues point to you or the camera/lens. If camera, the shutter didn’t open or perhaps the lens aperture went to a very small hole like F22 or 32. If it's operator error, you didn't remove the lens cap, meter correctly, or something else.
Good luck,
barondla
