Originally posted by TDvN57 Very nice work by him. Thank you for sharing.
Originally posted by bratzmahn Thanks for mentioning this excellent photographer!
...and of course, I think he was the last nudge for me to buy a used 645z!
I live not in such beuatiful landscape, but I try to make the most out of it...
Morning All,
I was really drawn to his work. I'm 70 and will probably never get a 645. Several years ago I acquired a K1 and that will probably be my last camera. In reality, it's all the camera I will really need (well unless I'm shooting in absolute pitch black night, with no moon, capturing foreground landscapes for the Milky Way, and then you can always use a bit more.....)
I've somewhat drifted away from wide angle per say - and started shooting a bit longer but in panos. I saw that his approach was very similar - but only he does it better, much better and has a much better eye and sense of composition. At least he has the common sense to shoot when there is light out - that makes a big difference. He also seeks out good light (as opposed to no light).
I find that shooting longer but wider (with stitching) frees you up from needing the immediate foreground, and lets you pull in more of the details in the mid distances (which makes your images sharper). Rather than trying to squeeze more scene into your fixed frame (the sensor), you are capturing the scene through the addition of pixels. I ran across a video of a photographer shooting a famous bridge in Paris, who shot it once with a wide angle lens to squeeze the entire length of the bridge in to the frame, then shot it again at 50mm stitched. Two completely different images - with the stitched one the better of the two.
Also, I believe that this technique complements the larger medium format sensor. The K5, K1 and the 645Z each have similar pixel sizes. The larger sensors (40 to 50mp FF and 100mp MF) with larger resolutions, has smaller/finer pixel sizes - which can result in finer details, which pushes needs higher resolution lenses (at much higher cost$). By going slightly longer in focal length, you are acquiring the finer details with increased sharpness, via the larger pixels - and can also user older vintage lenses with the older optical qualities and character that the new digital lenses (more clinical) tend to loose (by their design).
After growing up in California - I'm now out in the Arizona desert. I too think that - if only I was back in California, a beach, a harbor - boats and ships, a seascape, an inland valley opening up to the sea, or up in Seattle with some islands. I'm finding that your every day surroundings tends to really blind you to what everyone else sees. You loose the sense of what potential your local area offers. I go out at night, especially during the summer since it's so darn hot out (120 during the day).
I also use to go out and shoot night cityscapes with some architecture - but sort of drifted away from that too. I just need to get out shooting more.....
