11-03-2020, 05:45 AM   #1
SR On the 645D Which is the Best setting to Minimize Shake
I read the manual and it says if you use the Higher one the Battery is used up faster. How much Battery drain is there. I feel its best to use the Highest one to minimize camera shake when hand holding
If it goes on a tripod then are you suppose to turn it off ? Thanks
11-03-2020, 07:08 AM   #2
QuoteOriginally posted by rollsman4 Quote
The 645D (nor Z), lacks in body SR. The sensor is fixed. So the settings won't matter, unless you have one of the super expensive lenses with image stabilization built in. Believe there are only 2. The 28-45 and 90 macro.
Thanks,
barondla
11-03-2020, 08:55 AM - 1 Like   #3
QuoteOriginally posted by barondla Quote
Thanks,
barondla
What barondla says is correct. The Z does have video stabilzation, but that's different.
11-03-2020, 09:58 AM   #4
QuoteOriginally posted by texandrews Quote
Didn't know about the electronic video stabilization.
Thanks,
barondla
645d, 645z, battery, camera, medium format
HD Pentax DFA645 Macro 1:2.8 90mm ED AW SR - problem shake reduction broken ProfessorBuzz Pentax Medium Format 9 05-05-2019 07:22 AM
to SR or not to SR, that is the question Gian Pentax K-3 & K-3 II 22 12-25-2018 07:39 AM
What best free app to work with noisy K-30 DNG files and how to minimize it? Evie Digital Processing, Software, and Printing 14 01-16-2015 08:22 AM
How Best To Minimize Fringing? rormeister Pentax DSLR Discussion 6 02-20-2009 03:16 PM
Any tricks to minimize dust when changing lens. pcarfan Pentax DSLR Discussion 7 09-25-2007 06:59 PM
All times are GMT -7. The time now is 06:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
