Originally posted by Shaneuk Hoping some experienced people on here can advise on whether on what the situation is with expired film.
Shane
Initial cost of film photography: Low. Per shot cost of film: High
Initial cost of digital photography: High. Per shot cost of digital: Low
Variables when it comes to expired film:
a) ISO: The higher the ISO, the shorter the life span. The lower the ISO, the longer past due date usability. 200 ISO and lower can last for decades past the expiration date. 800 ISO and higher are most likely to suffer the most within a few years.
b) Storage temperature: Kept in a freezer, the film can last 10x longer. In a refrigerator, probably 5x longer. In room temperature, it's still probably 'usable' for a couple more years. In a hot car, it can expire before the expiration date.
c) Film type: B&W have the best longevity. Color slide film the least with color negs a bit better.
d) Pro or consumer grade: Films labeled as "Professional" are often no different than the others, but are supposedly handled differently. For example, pro films are supposed to be shipped and stored in refrigerated conditions. Pros often want consistent results, so pro films are also often sold in bricks (20 rolls), half-bricks (10 rolls), or pro-packs (5 rolls) at a time as they all were made in the same run with the same exact emulsion (vs. film made the day before or after).
e) Retail source: A camera store is more likely to have kept the film in cool conditions and the film has traveled less than an individual who may or may not have kept it cool.
OVERALL: My advice if you're new to film photography and new to your camera is not add another variable to your results with the film. Use new film until you know what you can expect from your camera and your technique before saving a bit on used film. If you get odd results by starting with used film, it's harder to know if it was you, the camera, the film, or the processing.
