12-31-2020, 05:00 PM - 1 Like   #1
TDvN57's Avatar
Bright point exposure
Sometimes when I shoot on a tripod with live view I look at the histogram to set the exposure so that the brightest part of the picture does not clip out in the bright side.
That only works in live view with the histogram. Would actually be nice if the auto exposure can be set to do the same, then instead of giving an average good exposure result, it would expose for the brights and let the rest be where they are.
Anybody else would use such a feature?
01-01-2021, 06:08 AM   #2
Michail_P's Avatar
Isn’t there a highlight protection option in the menu? What body do you have?
01-01-2021, 07:28 AM   #3
TDvN57's Avatar
QuoteOriginally posted by Michail_P Quote
645z. And yes it does have highlight protection. The objective is to push the exposure to just before the highlights will clip. Instead of an average value. Manually it is referred to as expose for the highlights, or something similar.
But perhaps the setting you refer to may achieve the same result, I'll look into it.
01-01-2021, 03:35 PM   #4
Wingincamera's Avatar
Remember the histogram you see is getting information from the jpeg, which will not have the total tonal range of the actual raw file.
01-01-2021, 04:42 PM   #5
Canada_Rockies's Avatar
QuoteOriginally posted by TDvN57 Quote
For bright snow I usually use meter the snow and add two full stops of exposure. That sounds close to what the quote says to me. I suppose you could meter a piece of white copy paper and do the same trick -- adjusted as necessary.
01-02-2021, 01:09 PM   #6
TDvN57's Avatar
I just read an article that said the Ricoh GR3 has highlight exposure option. B&H specifications mentions the same. Would be good to hear feedback from users.
645d, 645z, camera, exposure, histogram, medium format, view
Bright exposure mode in Bulb semaca Pentax K-3 & K-3 II 3 02-27-2017 05:30 AM
Tutorial for K-3 multi exposure modes: (Additive, Average and Bright)? zantaphia Pentax K-3 & K-3 II 16 09-05-2016 01:18 PM
Exposure in snow, bright landscapes, and anything backlit ThatsGreyt Flashes, Lighting, and Studio 7 03-10-2014 11:31 PM
Exposure time problem with k-x and bright light gelokrol Troubleshooting and Beginner Help 4 10-13-2013 05:17 PM
Pentax 55mm 1.4 Point to Point Focus Speed MBT74 Pentax SLR Lens Discussion 22 10-16-2012 06:35 AM
All times are GMT -7. The time now is 01:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
