Originally posted by MossyRocks It wouldn't surprise me if it does make that difference. The 3mm isn't much difference and with IR, UV and Bayer filters on top of the sensor that probably accounts for most of that 3mm. Add in that having that additional glass in the optical path and the effects of that and it probably does make up that difference. From what I remember reading and think I understand is that having additional glass in the optical path between the lens and film/sensor does change things up. I have found this to be the case with one of my big lenses that takes drop in filters where there is a noted difference in focus with and without a filter in the holder.
This seems like the kind of thread that could use some insight from @photoptimist as he always seems very knowledgeable on these sorts of optical performance types of things.
Thanks for the shout out!
Yes, a 3 mm difference between the official flange focal distance and the measured flange-to-filter distance on the sensor sounds well within the realm of possibilities. The range of glass filter thicknesses for digital cameras range from about 1/2 mm to 4 mm (
Sensor Stack Thickness: When Does It Matter? ). Then there's also an air gap between the filters on the front of the sensor and the chip surface. That gap is about a mm or so and is needed for the space for the microwires that connect the silicon chip to the traces inside the body of the sensor.
A photo of the 645Z cut in half (
https://upload.wikimedia.org/wikipedia/commons/6/69/Pentax_645Z_cutaway_2015_CP%2B.jpg )shows a thick stack of what looks like 3 sheets of glass or filter materials between the shutter blades and the silicon.
Finally, it's worth noting that if the 645Z flange-focal distance were longer than that on the film era 645, the effects on focus-at-infinity would be most strongly felt with film-era wide angle lenses such as the FA 35 mm lens. Just a 0.5 mm increase in the flange-focal distance would move the infinity focus of a 35 mm lens to a mere 2.5 m.
