03-19-2021, 03:15 PM - 3 Likes   #46
672
behind the scenes
heres the prep , working on the captures now , will post another time
IPhone 7  Photo
IPhone 7  Photo
IPhone 7  Photo
IPhone 11  Photo
03-19-2021, 04:28 PM   #47
QuoteOriginally posted by 672 Quote
You're a better man than I, Gunga Din! That would scare the bejeezus out of me, hanging my Z out like that!
03-19-2021, 05:40 PM   #48
QuoteOriginally posted by texandrews Quote
It appears to be firmly attached. This is surely going to test the shake reduction of that 28-45 though!
03-19-2021, 10:31 PM - 2 Likes   #49
672
whowasiworkingfor?
fed ex?
03-19-2021, 10:33 PM   #50
672
whowasiworkingfor?
the feds?
03-19-2021, 10:39 PM - 2 Likes   #51
672
none of the above?
03-20-2021, 06:56 AM   #52
TDvN57's Avatar
Great shots 672....
Not my cup of tea, so to speak, I don't like heights and as long as the plane's engine is working I'm not leaning out the window or door.
03-20-2021, 10:32 AM - 2 Likes   #53
672
flying
...it was a great flight and the 28-45 performed quite well. This was the one time I can honestly say I wish I had that 25mm...... The 28-45mm is not as sharp side to side when shooting straight down as it is when looking forwards, I suspect the 25mm prime would perform better in that regard, due to less moving parts and overall weight....
heres a clue as to which photos were for assignment
IPhone 7  Photo
03-20-2021, 12:18 PM   #54
Hey, got some questions about this last one:
  • What did you use to attach the camera to the cross pole? Looks like a gimbal...? Or just some kind of bracket...
  • How much stiffer did the 2 angle poles make the cross pole?
  • How springy was the cross pole?
  • What was the metal of the poles? Galvy, or aluminum?
  • Do you think square stock would have been stiffer for the cross pole?
  • How did the cross pole react with the wind?
03-20-2021, 01:14 PM - 1 Like   #55
672
questions
thx texan!
the camera is on a Wimberly Gimbal version one.
the two angle poles stiffened the cross bar significantly
the cross pole was quite springy , esp in desert winds. perfect for 500th of a second (or greater) with IS on. I did one video reference with the 1DX2 hang and the rolling shutter was like jello in an earthquake......
the poles were aluminum 1 1/4" with steel sleeve connectors. each pole is six feet long.
if more rigidity was the objective I would have used one 30 foot length of steel pipe and a ten ton truck to bring it and more assistants , instead of one.. mobility was key.
the desert wind that day was around 11 MPH and the cross brace was fine, but we wrapped the set up well before the afternoon winds of 21MPH......
03-21-2021, 06:37 AM - 1 Like   #56
w2ck's Avatar
Hi,
Aw, just a little bit higher than you were on the lift.
Really cool there, both the lash-up and the shots.
Stan
03-21-2021, 09:18 AM   #57
thx texan!
Thanks, good info Here's something to look into that I have used before: Superstrut 1-5/8-in x 1-5/8-in Silver Electroplated Half Slot Channel Strut in the Struts department at Lowes.com
Will also be available at other places, of course. Find it in the electrical department with conduit. I *think* it's stiffer than other options. Not sure about all the lengths available at your local Lowe's or HD, but there are connectors I think. A specialty electrical or steel supplier could be a better bet. The holes can be handy.
Here's another thing that I found out from something unrelated to photography. If you take square stock steel and mill off a millimeter or so off of one side, it comes out with a bow from the milling. If you put the bow up, then load it the bar will wind up straight. It's a complicated story how I found that out....
03-21-2021, 06:05 PM   #58
TDvN57's Avatar
That is a smart idea in this application. in long span roofs we've used a similar technique where the roof is built with a "bow" and when it is finally under full load the bow is reduced to almost flat. Is called pre-camber.
03-21-2021, 07:11 PM   #59
672
strut
oh yeah that strut material would take some load for sure. I tried to make a bridge like support with ratchet straps and a short perpendicular pipe but it had to be from the bottom to flatten the main pipe, so was in the way of the camera and head......
03-22-2021, 05:43 AM   #60
QuoteOriginally posted by TDvN57 Quote
Flat trailers for semis are made this way too. Just my 2 cents. (I worked on semis as a summer job when I was a University student). Most reinforced concrete structural beams are designed this way too.
645d, 645z, camera, flickr, format, image, john, lens, location, medium, medium format, mike, moon, moonee, picture, pm, post, scenes, shot, shots, sky, teleconverters, thanks, thread, trail, tripod
Post your medium format photos! Nesster Pentax Medium Format 20445 14 Hours Ago 02:20 AM
Post your medium format f 2.8 Photos! (f 2.8 or wider ONLY!) ivanvernon Lens Clubs 49 02-02-2021 03:22 PM
Post your non-pentax medium-format and large-format pictures DenisG Canon, Nikon, Sony, and Other Camera Brands 26 12-07-2020 08:02 PM
Behind-the-scenes of shooting the flipped iceberg photos in Antarctica interested_observer General Photography 2 02-08-2015 12:24 PM
Photos from "Behind the Scenes" maconmatt Post Your Photos! 3 08-25-2009 12:40 PM
All times are GMT -7. The time now is 04:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
