I have used the "Vello RS-C1II Wired Remote Switch for Select Cameras with 2.5mm Sub-Mini Connections" with my Pentax cameras. Below I describe how it performed and also a shortcut to the product at B and H is listed. Please note that as I say below, the product only worked intermittently at first, and after I filed down the base of the plug it seemed to perform as it is supposed to a majority of the time. I am not sure if it does perform with the 645Z, but as I said it has with my K-5IIs and K-3II.
I have never used the CS-205 so I do not know how it performs.
At first I found that this product (Vello RS-C1II) worked only intermittently with my Pentax K-5IIS and K-3II. I found out later that this was due to the plug not sitting deep enough in the camera socket. So per some advice from a forum member, I filed down the plastic part of the base of the plug. Since then it has worked fine.
https://www.bhphotovideo.com/c/product/765659-REG/Vello_RS_C1II_RS_C1II_Wire...981&
EDIT Please note that another reason why I was told the plug on the model of this product I mentioned would not make a total connection with the Pentax camera originally, was that the plug was not straight, that it was turned at an angle. So, I noticed that there is a plug with the same name on Amazon that shows a straight version of the plug, which may possibly perform better. A shortcut to the product is below.
https://www.amazon.com/Vello-RS-C1II-Remote-Switch-Select/dp/B007CB58NY
