I have a Pentax "67" and several lenses that i purchased about 15 years ago from the original owner. I used the camera pretty regularly for a couple of years and for the last ~10 years it's been stored away. i'd take it out occasionally and put it through its paces but it hasn't seen much regular use. It's overall in excellent condition - looking mostly new still.
So i took it out last weekend with a fresh battery and put a few roles through it and it works perfectly well. Something i noticed though is that when mounting a lens to it there's a good deal of friction between the lens and the body - it doesn't feel like anything's out of alignment, more like there's some adhesive almost causing friction. I get the same feeling when mounting or removing any of my lenses.
Maybe related to this i notice that the light seal material between the prism and the body is degrading and turns into an almost rubbery material. As far as i know this camera's never been serviced and i'm sure it could use a service but there's nothing clearly wrong with it other than this peculiarity.
I might try to gently clean the lens mount with a q-tip and some 99% alcohol to see if that validates my theory and addresses the issue.
I'm wondering if anyone else has had this happen and at the same time does your lens mount to the camera smoothly or is there a bit of friction when you do it.
Here's a picture of most of my 67 kit (attached)
