04-10-2021, 09:17 AM   #1
pentax 67 lens auto mode
so this morning , I started taking pictures for my new work with my pentax 67 after i finished taking all the pictures I started to take the film out and noticed the len was switch to auto all this time , I known that the auto mode it supposed to work with ttl prism but I don't have one I was using a standard prism with external light meter. So after I noticed I was quite scared about all my pictures is going to waste .
If anyone had this problem before can someone tell me the outcome ?
04-10-2021, 09:43 AM - 1 Like   #2
Auto just means that the lens stops down to your selected aperture when the shutter is fired - which is probably what you're used to. Manual on these lenses is the same as DoF preview on other camera systems - when you change aperture it changes what you see in the viewfinder (increased depth of field if you can notice it, and lower light levels).
You can easily play with both without having to shoot a frame, and if you take the lens off the camera there's a little lever on the rear of the lens that the camera triggers upon shooting the frame that stops the lens down to the set aperture, you can wiggle the lever and see what happens to the lens aperture
Either way you have this set shouldn't affect the final image.
04-10-2021, 10:09 AM   #3
thank you very much !!
04-10-2021, 03:26 PM   #4
Not all 67 lenses have this Auto/Man lever but the ones that do, are supposed to be shot in the auto mode, unless there is something used between the body and lens that disallows the auto diaphragm action (like the helicoid ext tube).
645d, 645z, auto, camera, medium format, mode, pentax, pentax 67 lens, pictures, prism
Pentax 67 vs 645d vs 645z with 67 Lenses reivax Pentax Medium Format 13 11-17-2019 03:41 PM
K1 green mode (full auto) and semi-auto biz-engineer Pentax K-1 & K-1 II 10 04-26-2018 01:02 PM
Pentax KS2 + 18-135 (no auto mode/ no scene mode?) hr21 Pentax DSLR Discussion 9 02-13-2016 04:21 PM
P645NII, 67>645 Adapter, 67 Auto Extension Tubes? ASA32 Pentax Medium Format 4 05-24-2013 09:27 AM
For Sale - Sold: Pentax MH-RA 67 and MH-RB 67 lens hoods RBullCZ Sold Items 5 08-07-2011 11:35 PM
All times are GMT -7. The time now is 02:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
