05-03-2021, 08:31 PM   #1
TDvN57's Avatar
645 Teleconverter Conversion with Autofocus?
Was looking at the 645 teleconverter and wondered what would be involved in adding autofocus to the 1.4TC. It seems as if it could be possible to add the screw-drive functions by salvaging components defunct 645 cameras and 645 AF lenses. The "lens" side looks fairly possible, however the "camera" side of the TC might be more complicated. It would require someone with machinery that can manufacture the components to fit on the "camera" side of the TC.
The other side to consider would be the practicality of autofocus on a converter. Adding a TC to lenses with f5.6 may not have enough light to enable autofocus.
Any thoughts on this?
05-03-2021, 10:30 PM   #2
QuoteOriginally posted by TDvN57 Quote
Doubt an individual could pull off a screw drive af converter mod. It would likely take a well equiped company to do it. Do any of the tele lenses use SDM? If so a converter with electrical contacts on both sides, wired together, could af.
Unfortunately the F5.6 maximum lens opening would probably make the 1.4 converter iffy at best. The 300 F4 might do better. Would the 300 F4 with 1.4 converter match the IQ of the 400 F5.6?
We could just crowdfund an ultratele after the ultrawide 😊.
Thanks,
barondla
05-04-2021, 03:33 AM   #3
Andrea K's Avatar
You need a lens mount with all contacts, a camera mount with all contacts and a transmission shaft for the screwdriver AF.
05-04-2021, 04:56 AM   #4
Even if you could machine it to the necessary precision, the torque and misalignment on the drive shaft would likely be a problem.
05-04-2021, 07:14 AM   #5
Andrea K's Avatar
we would need a watchmaker
645d, 645z, autofocus, camera, components, lenses, medium format, tc, teleconverter
Abstract ROCKS, 645Z + 645 FA 200 mm f/4 + 645 1,4X teleconverter. RICHARD L. Post Your Photos! 3 02-16-2021 03:16 PM
645 vs 67 lenses for digital conversion mjm6 Pentax Medium Format 14 11-12-2018 08:52 AM
6x7 to 645 focal length conversion? elsdad Pentax Medium Format 3 01-20-2013 07:13 PM
Pentax 67 to 645 conversion chart elsdad Pentax Medium Format 8 06-12-2011 02:33 PM
Autofocus conversion of MF lenses leaton Pentax DSLR Discussion 7 10-30-2006 01:33 AM
All times are GMT -7. The time now is 07:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
