Hi,
Here are the common sense tips of how to store lens (
https://www.sharkandpalm.com/photography-tips/how-to-store-camera-and-lenses...e-value-high): 1. Store them front-element-side-down.
This will minimize the presence of oil in your aperture blades (which can really gum up the works when you try to change your aperture in the future). This has become less of a necessity with modern autofocus lenses that use less oil in their manufacturing, but it’s better to be safe than sorry.
2. Close aperture rings to the smallest f-stop to reduce tension on the springs.
The springs in your lenses, like any other springs, fatigue over time. To keep your lenses like-new, set them to their smallest aperture (in other words, the highest number on your lens) when you store them. If your lens doesn’t support manual aperture adjustments, just close up the aperture using your camera body before you turn it off.
With regards to entry 2 here is a question:
If an aperture for example needs to be set to 22 (as the smallest one) then is it just enough to turn the aperture ring to 22? That’s it? In such a case the blades don't close down physically to the smallest aperture, they stay hidden.
Or do I need to turn the aperture ring to 22 and then to switch the depth view lever from “auto” to “man” to make the blades close down to the smallest opening?
Your answers are more than welcome.
Gennady
