Originally posted by barondla Don't think two 1.4x converters will mount together. It is unfortunate an extension tube won't fit on the front of the 1.4 converter. If it fit, the smallest tube would allow mounting two 1.4 converters together. Would also allow 1.4 converter on 90 macro and other lenses with insufficient mechanical clearance.
Thanks,
barondla ( always trying to use parts together in strange ways)
For the curious, the incompatibility between the 1.4X converter and the extension tubes is due to the tubes containing a rectangular 'mask' that interferes.
For the case of the 1.4X teleconverter mating to another, the distance from the most protruding metal at the front of the 1.4X teleconverter to the electrical pin flange is 11 mm, while the distance at the back from flange to glass is only about 8 mm.
Richard L.'s experience with the 2X differs from that of the single reviewer in the lens reviews section. Are there a preponderance of reviews elsewhere trashing this device?
