The other comments about stabilizing a long lens are not wrong. Any long focal length lens will become a challenge because the dof decrease and focus becomes more critical. Add to that any small movements will become large optimal swings because of the small angle of view, 5.2 degrees diagonal on digital. Consider also the distance from you to the object. The further away the larger the optical swings will be.
A stable tripod and some weight on top of the lens combined with mup will all help to minimize micro movements.
On the other hand you can also minimize some of these effects by closing down the aperture, which will help greatly with focus, and increase shutter speed to freeze a smaller amount of time, hence less negative impact from the micro movements.
Contrary to intuition I found that a gimbal is more stable than a ball head tripod head. A video fluid head is also better than a ball head, but not as good as a gimbal. I think this has to do with vibration dampening and the diameter of the shaft connecting the ball part of the ball head to the camera mounting plate.
Be that as it may, combine these and you can get fairly stable shots even with a 1.4 TC, even when you mount this on a gimbal and monopod, yes not a spelling error, monopod. When I discovered this by accident I decided to take the 600mm lens with me on a trip to Southern Africa and did a test shoot-out one afternoon. My thinking was that if it fails, then I'll put it back into my bag and use the other lenses instead. The results surprised me, considering that these pictures were taken from a safari jeep, mostly stationary during shooting, but other people moving around constantly. I placed the monopod between my legs or on my side, so that I could get the target object conveniently in view.
Here are some pictures with the 645z + 600mm some with 1.4TC, all on gimbal and monopod, from the safari jeep.
The last picture of the kingfisher I was on foot in the Philippines in one of their National parks. 645z + 600mm on gimbal and monopod.
