Originally posted by Gyroscope It's more a case of my wondering if I should accept 'good-enough' over 'perfect' for the sake of simplifying my kit and getting a lens set that allows me to shoot more diverse subjects.
I see you point very well. In 2016 I had multiple cameras and too many lenses , and I decided to simplify my kit around a single system to do all my photography, built around the Pentax K1, and now I've being thinking for a while about getting two systems again: full frame or apsc for wildlife, and medium format for wide to short telephoto focal lengths! And I'm going to tell you my reasoning here: I've figured my depth of field limits.
For me, ultra-wide up to 35mm FF equ. benefit from larger formats, it is so for 3 reasons:
1) Depth of field increases by the square of decreasing focal length, required shutter speed also decreases with decreasing focal length => direct image resolution + image quality gain with larger format
2) Image stitching without seams: very difficult to do with FL wider than 35mm equ. on full frame => advantage single exposure medium format
3) Autofocus requirements are low for wide angle imaging => medium format fits the bill.
On the other side of the spectrum, smaller formats win for supertele, sports, wildlife, macros, thanks to the extra "crop factor", choice of lenses, auto-focus performance, faster frame rates and mobility. Furthermore, the need for resolution is lower for single subjects (such as wildlife, portraits, macros..) due to the subject magnification in the frame. In other words, one can shoot an elephant with an apsc camera, make an XXL print that still show plenty of subject detail.
So, after trying to rely on a single system (K1) I realized the old Pentax approach of dual systems (apsc + MF) was a good approach. And I can see Fujifilm copied the old Pentax dual system approach: Fuji X + Fuji GF, having enough separation in terms of speed vs image quality for the two systems.
Full frame is the most versatile but at the same time it is a compromise.
