Originally posted by Chiron2411 Thank you! I am going to try the fine adjustment on my lenses - haven't done that yet. Also going to switch to back button focusing and try to get used to that.
You're welcome.
I use Focus Tune to help with fine adjustment.
Originally posted by Chiron2411 How did you set up the 4-way dialpad to quickly adjust autofocus point? I haven't been able to find that option
[AF Area] is the secret to everything!
Press and hold it.
You will see the display switch, showing you to use the back dial.
Rotate the back dial to the mode you want. Eg SEL with the 1 red dot.
Then the 4-way buttons will let you move the red dot one around.
Also, the button with the 4 arrows (it's just down and left from the 4 way buttons) will toggle the operation between moving focus point and normal 4-way buttons.
It's worth investing sometime to review the manual on how this works, and to practice with it.
Good luck!
