Originally posted by RICHARD L.
The older 645 A 55mm f/2.8 is really inexpensive and is quite sharp but I found my copy lacked "detail-gathering ability" for infinity compositions. However it is amazingly good for mid-distance subjects, has high contrast and renders beautiful colors. It is light and produces a bright viewfinder image, making it easy to focus. Pay a little more maybe but get a "like-new" copy if you can, as some of those offered used on eBay have seen better days.
f/11 is the optimim aperture.
---------- Post added 02-01-23 at 03:23 PM ----------
If you already have a P67 55 mm f/4, then you know it is one of the best lenses available for medium-format Pentax cameras. The genuine Pentax "67 to 645" adapter permits autoexposure in Av mode but focusing may be a little harder (f/4). It can be used practically at any aperture opening and the pictures it produces on the 645 format have no equal. The adapter will cost between 150 to 200 US dollars, about the same cost as a used 645 A 55mm f/2.8.
the P67 55 mm f/4 is a "über lens".
Since I apparently can't use the
DFA 55mm F2.8 AL on my 645NII using bulb mode, which is
incredibly dissappointing as I do a lot of long-exposure night photography a la Todd Hido, I guess the questions now become:
-Should I just make do with my
P645 FA 45-85mm F4.5 that I already own? (It's an autofocus zoom, so I don't know how sharp this lens compares to the two prime 55mm lenses mentioned below.)
-Should I purchase the
P645-A 55mm F2.8 as it's lighter and a few stops brighter? (Being an older lens, I honestly don't know how this stacks up against the newer FA 45-85mm F4.5 or the SMC P67 55mm F4 in terms of sharpness.)
-Or should I get a genuine, newish
P67 to P645 Adapter like Richard L. mentioned above and attach my
SMC P67 55mm F4 to my 645NII, particularly if my SMC P67 55mm F4 is the sharpest of these 3 lenses?
Without sounding like I'm overthinking it (which I likely am), basically what I'm asking you more experienced shooters is which of these lenses will be most useful as a walk-around lens and has the ability to render maximum edge-to-edge sharpness for late-in-the-day/night photography (which I always shoot using a tripod)? 55mm is my preferred focal length for 645 film, by far, so a 55mm lens would stay attached for 75% of my photographs. I just have to pick the right one!
Thank you guys for the help and suggestions!
