Hello all,
I should have mentioned that I also have a Pentax 67II with the following lenses (all are the latest SMC versions): 45mm f/4, 55mm f/4, 105mm f/2.4, 200mm f/4, and both 55-100mm and 90-180mm zooms (both are super heavy, but sharp).
I currently have the FA 45-85mm f/4 and FA 80-60mm f/4.5 zooms for my Pentax 645NII. Due to their weight, these lenses aren’t really ideal for street photography. I need a lighter setup.
That all said, I wanted to get your opinions on what lenses I should get next. I have two options that I wanted to run by you guys:
Option 1: I was thinking of purchasing the
(645) FA 75mm f/2.8, the
(645) FA 55mm f/2.8 AL, and the
(645) FA 120mm f/4 Macro since they’re all pretty small, and I can easily walk around with any of these lenses on the camera. (I’m thinking about eventually getting the Fuji GFX 100s (or, better yet, the currently hypothetical 100mp Pentax 645Z Mark II), and perhaps these lenses can be adapted and work well with these newer medium format digital cameras?)
Option 2: Get the
Pentax 67-to-645 lens adapter and purchase the
(67) 75mm f/4 and the
(67) 165mm f/4 (leaf shutter) lenses, which would fill out my Pentax 67 lens lineup (letting me replace both of the heavy 67 zoom lenses) and can be adapted for use on my 645NII, along with all the other Pentax SMC 67 lenses I have.
All considered, option 1 would be nice because all those lenses are very good, very light, have autofocus, and allow for data imprinting. Option 2 would fill out my Pentax 67 lens lineup and can be used on my 645NII, however there would be no autofocus, probably no data imprinting, and would still be somewhat heavy. I use the Pentax 67II for more serious work and the 645NII for more spontaneous/casual work.
What do you guys think I should do?
If it helps at all, I’m almost exclusively a landscape film photographer, however I’m looking for a more spontaneous way of working (hence why I purchased the Pentax 645NII in the first place). You can see my work here to give you a better idea of what my photography is about
kristianwolfe.com
Many thanks to you all for all your help and suggestions!
