Show Printable Version 65 Likes Search this Thread
11-10-2021, 10:01 AM   #1
TDvN57's Avatar
Is it time to ditch the SD card concept?
Just watched a review of the new Mavic III drone with Hassie 4/3 camera and no removable storage.
According to the reviewer it has a 1tb SSD built into the camera. To make it practical the camera connects with USB-C.
I've wondered about this concept for some time now and I recall a short discussion about as well here on the forum.
But realistically, if we can enable ourselves to temporarily let go of what we find as must-haves in a system and consider what new technology offers, then it opens up new horizons. For example if there was a SSD solution available at the beginning stages of digital cameras, would they have ever considered a small removable cartridge, eg SD card?
A built in SSD solves a lot of issues, the biggest advantage would be no need for a large buffer because the SSD can write fast enough.
With regard to reliability, well my MS-Surface has a 1tb SSD built into the motherboard and it is still working everyday.
If reliability is a serious concern, perhaps a second 1 or 2tb SSD also built in could solve that concern as well.
Transferring data off of the camera with USB-C is fast and there are various options available such as a laptop, or a storage unit with the smarts to dump the incoming data onto a SSD and/or plugin drives. There are a couple of these devices in the market.
What are you your thoughts? Could this be a viable solution for Pentax to add to a 150mpx FF 645 one day?
11-10-2021, 10:16 AM - 1 Like   #2
StiffLegged's Avatar
It depends on how long the SSD lasts compared to the shutter - SSDs have a finite life in read/write cycles so you wouldn’t want a camera’s storage to expire before the shutter wears out as an SSD soldered to the other circuitry wouldn’t be easily replaceable. SD cards (or whatever flavour) can at least be easily replaced if they fail.
Should Pentax move to a shutterless body like Nikon just have with the Z9, the lifetime of an SSD becomes more of a consideration, I think.
11-10-2021, 10:44 AM   #3
AggieDad's Avatar
I think an SSD is a very practical idea. I suspect it could be a "plug-in" of some sort that could be replaced if needed. Although, I must admit the SSDs I have for my computers have shown excellent reliability.
An idea for Pentax? Probably not. My impression is that Pentax does not want to be anywhere near the forefront of any change or innovation.
11-10-2021, 11:05 AM   #4
Modern quality SSDs should last way longer than the shutter in most cases.
11-10-2021, 11:18 AM - 7 Likes   #5
Fogel70's Avatar
I would not like a non removable storage.
In case the camera breaks down it cannot be fun to no longer have access to the images.
11-10-2021, 11:35 AM - 7 Likes   #6
Not a Number's Avatar
If for some reason I had to give up the original images I would rather turn over a memory card than the whole camera.
11-10-2021, 11:51 AM   #7
Eric Auer's Avatar
QuoteOriginally posted by Fogel70 Quote
In case the camera brakes down it cannot be fun to no longer have access to the images.
Not an issue if the drive can be powered from the micro USB port as well as from the camera.
Pretty sure this will be the case on any somewhat serious camera with a fixed drive.
Also would not surprise me if the camera also had wifi that can run off the camera battery independently for even more transfer options.
11-10-2021, 11:53 AM - 1 Like   #8
Eric Auer's Avatar
Pretty sure most semi pro/pro cameras will have a SD slot as well or something else removable.
11-10-2021, 12:01 PM - 3 Likes   #9
jlstrawman's Avatar
QuoteOriginally posted by Eric Auer Quote
https://www.techradar.com/news/what-is-cfexpress-the-new-camera-memory-card-format-explained
11-10-2021, 12:04 PM   #10
Fogel70's Avatar
I'm not sure that would be possible if the main board is damaged, FI by water intrusion.
11-10-2021, 12:19 PM   #11
Eric Auer's Avatar
Whats your point?
11-10-2021, 12:21 PM   #12
Eric Auer's Avatar
I'm not sure thzt would be possible if the main board is damaged, FI by water infusion.
Or if the camera was in an explosion, fell in to a void, burned in a fire etc etc.
Sigh...
11-10-2021, 12:37 PM   #13
I welcome cameras with fast internal storage, fast transfers, and no need for slow removable cards.
The Mavic 3 w/ 1 TB SSD costs $5000 USD. It's easy to include the SSD at that price point. It will take longer for SSDs to become common cheap enough for $1000 cameras.
Others have mentioned concerns about SSD lifetime. With the wear leveling built into a modern SSD, mechanical parts of the camera will fail before the SSD.
Another consideration is the physical size of an SSD. Can it fit into than the card slot area of a compact camera?
11-10-2021, 12:41 PM   #14
Eric Auer's Avatar
QuoteOriginally posted by DeadJohn Quote
Well, it wouldnt have to be in the card slot area at all.
11-10-2021, 12:45 PM - 3 Likes   #15
35mmfilmfan's Avatar
I use one 64GB SD card per year in my K3. I have a stock of ten unused ones. I fully expect there to be some left unused by the time I no longer need them !
645d, 645z, camera, card, concern, data, ditch the sd, medium format, reliability, sd card, sd slot, ssd, time to ditch, usb-c
K-1 SD Card write time: gets worse with time? HippyHippo Troubleshooting and Beginner Help 21 01-06-2019 11:43 PM
SD card Just bought an Sandisk Ultra SD XC1 64 Gig Card and comes up with error Craig Hickman Troubleshooting and Beginner Help 10 07-30-2018 11:37 PM
For Sale - Sold: Fuji F550EXR, 4GB Eye-Fi SD Card, 4GB SD Card, 2 Batt + 6BQ5 Sold Items 3 09-16-2013 08:19 PM
Crap! My new class 10 sd card run much slower than my old class 4 sd card... liukaitc Pentax Camera and Field Accessories 15 05-31-2011 01:39 PM
All times are GMT -7. The time now is 09:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
