Originally posted by tuco When you remove the lens, the aperture chain moves all the way in one direction (as if you set the lens to f22). And when you mount the lens it moves back to whatever aperture the lens was set at. .
On my 67, the chain position at f22 is not the same as when the lens is removed. At f22, the chain is already pulled part way. On my 55mm lens, the chain is out about half an inch at f22, and on my 105mm lens the chain is out about a quarter inch at f22. Only removing the lens fully releases the chain. Is this not right? I've tried the suggestion of toggling on/off and moving to f22 and back, but no dice... Only loosening the lens (fully releasing the chain) seems to do the trick, and it works every time.
