The LS lenses are designed to give higher speed sync with flash exposures. They use the X sync from the lens to fire the flash, unfortunately there are no electrical contacts between the lens and the body. It uses the aperture lever that normally closes the aperture to also release the shutter in the lens. With the 67II you can still use older style automatic flash however not with your current flash. The AF400T can be attached in place of the left hand grip with the dedicated handle and a synch cord connected to the X synch which will enable you to have "auto" flash using the flash's inbuilt eye to quench it once enough light has reached the unit. A little clunky in the modern world however you can get correct flash exposure with synch speeds up to 1/500th of a second at any aperture that the power of the flash can handle.
PENTAX AF 400T Bracket for 6x7 Camera reviews - Pentax Camera Accessory Review Database PENTAX AF 400T reviews - Pentax Camera Accessory Review Database
The LS lenses still work well as "normal" lenses so if you need the focal length and the lens is nicely priced go for it. They were designed to help with shorter shutter speeds than 1/30th sec , good luck with your photos and on the hunt for your flash solution.
