Originally posted by biz-engineer
With Canon, the ink gets significantly cheaper for the 24" and larger printers, advantage given to professionals and semi-professionals. No sure about what the pricing is with Epson? I was close to buy a Pro 4000 because those beasts cost no more than a high-end digital camera and I found it doesn't make sense to have a high end camera and no means of printing to use the imaging potential of the camera. I decided to go with a few labs instead of getting the printer, because with lab I don't need to store print media and pay for the maintenance costs, but I don't get some of the print media I'd like to have, and hard proofing with distant labs is a very slow process and adds to costs. It's interesting how much marketing goes into selling cameras and how little marketing is done for printers. The printer section at DPReview is almost dead, however reviews for new camera models and smartphones are like constant rain downpour.
I've been lucky so far, the Epsons have been very reliable and I did not have to do any call-out maintenance yet. But I follow their recommendations and the Epson tech that helped to install/setup the first one told me to never shut down the printer. You put it in auto sleep with a periodic wake-up and auto clean (settings adjustable).
Only once did I have a few clogged nozzles after a period of abt 3 months of no use,
touch wood so far :-) Between the P7000 and P9000 I must have done close to a 1,000 prints in the past three+ years. Clearing a clogged nozzle is quite easy and is a simple auto cleaning routine with a test print afterwards.
For ink prices you can check B&H. For the P7000 and P9000 (use the same cartridges) you can buy different size ink cartridges. I bought the 700ml which works out to be just over USD 1,000 for a full set. Thereafter it is less, because you only buy the colours you use most. Unfortunately here in HK we are under distributor restrictions and we pay about double the B&H prices.
The printer comes with a set of small ink cartridges, but you use those to prime the heads. After the priming there is very little ink left. I managed to do a deal with the supplier to include the initial startup set of ink plus a full set of 700ml ink. I still have some spare cartridges.
Gosh sounds as if I am running a marketing campaign for Epson!!
Farming out the printing to a print house does make sense if you can get someone that you can work with, willing to do test prints and make adjustments until you are happy with the results.
