Originally posted by biz-engineer Yep, instead of a shutter slit moving over a sensor, it's the sensor that moves across the frame, albeit at a much slower speed.There are some commercial versions of scanning backs, although I'm not sure how many of those companies are still alive.
https://en.wikipedia.org/wiki/Digital_scan_back
I haven't used a document scanner for a long time, except the ones that are now part of office copiers, but if I remember correctly A4 sized document scanners were inexpensive and I was impression by the PPI resolution at the time I used them.
I’ve got zero large format experience, but I’ve read up on it a few times over the years and that Wikipedia article raises some questions.
1) Wouldn’t the long exposure times be a limiting factor in what subjects you shoot (compared to say 400 speed sheets)?
2) The Wikipedia entry is a bit dated, but it says “Another downside is that most of these backs have to be used tethered to a computer. One reason is that there would be no other way to know when critical focus has been achieved.”
I’d think you’d still focus using the ground glass, then mount the scanning back, and finally remove the dark slide. Right?
