Originally posted by RICHARD L. I purchased a like-new copy of this lens exactly one year ago for a similar price (peanuts, really) and posted an evaluation in the "Lens Review" section. It is true it is surprisingly sharp for such an old, simple 4-element design. One problem is handling such a gigantic lens (I learned the hard way ...). You need a Gimbal support with an Arca-Swiss quick-release plate if you do not wish to sweat profusely during an unwieldy mounting on a tripod ordeal. Finding critical focus is another problem as the viewfinder image is a little dark and the image is difficult to judge adequately. But when you nail it correctly, images are splendid on a 645Z. The diaphragm must be closed at least one stop (i.e. @ f/8) as images look a little "flat" wide-open. It accepts the P67 1.4X converter without any vignetting on the small 645Z sensor.
Best Regards P67 500 mm @ f/16 Hey Richard,
I actually read your review and that is what made me push the button on the purchase
. I have tested it with both the 1.4x and 2X 67 converters and it performs well. I think what I did with the lens mount makes a
huge difference. I was going to post this in my lens review but with the weather we are getting it may be a while for field work. Here is what I did and in my opinion it took the "handling" from a score of 5 to a score of 8.5
While there are a few design “short comings” affecting the usability of this lens, the main problem being the balance of camera & accessories, but it is well worth accommodating these. Using it with a full size gimbal head (not a side mount) and fabrication of a “lens foot” makes it into a valuable medium format telephoto.
As this lens is not internal focusing, almost everything forward of the aperture ring is moving. This makes the addition of “stabilizing” hardware not an option. In testing I used every accessory combination (extension tubes/extenders) and found that to be able to balance the various configurations, there needed to be a mounting rail of a minimum of 6 to 7” long. It goes without saying that it needs to be a quick release rail to be able to slide the lens back and forth safely.
The lens rotating/mounting collar, while being generously long and supportive, and quite wide on the bottom, only extends down 3/8” below the barrel of the lens and the focusing collar. Mounting a 7” rail extends almost half way along the focusing collar making it impossible to get your fingers between the rail and the collar for focusing.
The solution is to use a fabricated “lens foot” for mounting, to allow finger space to access the focusing collar and also to move the center of the lens barrel up higher on a gimbal cradle arm, providing better balance being closer to the swing arm pivot point. An added benefit of a “foot” is that it allows you to carry the lens with one hand rather than cradling it in your arms (an important feature in the field).
Procedure to fabricate a Lens Foot:
(1) Mount the lens plate across the bottom of the lens collar tripod flat, not longitudinally (which is normal).
(2) Using a ½” thick base rail is better than a 3/8 one, and a 6” long rail is OK, but a 7” gives a little more adjustment if you don’t mind the additional length.
(3) Use a clamp (2.375”) that is almost as wide as the lens plate is long, orientate the jaws of the clamp to be crossways on the base rail, with the knob at the rear, and use two anti-twist pins between the clamp & rail.
(4) Because this foot will be semi-permanent it is advisable to use Loctite Threadlocker Blue 242 on the lens plate and clamp mounting screws. Blue 242 is designed for the locking and sealing of threaded fasteners which require disassembly with standard hand tools.
Lens Foot Bill-of-Materials
Hejnar Photo C1-275 Lens plate
http://www.hejnarphotostore.com/product-p/c1-275.htm
Hejnar Photo E030-60 6” x ½’ Rail
6.00 x 1/2 Inch Base Rail
Hejnar Photo E030-70 7” x ½’ Rail
7.00 x 1/2 Inch Base Rail
Hejnar Photo F62AB 2.375’ Wide clamp (request 2 only anti-twist pins)
2.375 Inch Jaw Length Clamp
I had an old Kirk Enterprises one in my "spares" drawer so that is what i used.
Murray
