Originally posted by Michail_P
A very technical matter which I have researched just a bit, a while ago. CoC remains a not-so-easily perceived issue, due to the minimal scale of value comparison. Your insight is most interesting and the conclusion even more. Most folks would think “the bigger the better” , but the technological limitations indicate a necessity for balanced aspects.
One particular phrase caught my attention: “our best lenses cannot resolve details to match the pixel pitch of current sensors”.. Now, I get the terminology, pixel pitch etc, but is there really a way to compare lens resolution to sensor pixel pitch ??
Hi Michael, There is a simplistic way to get the basic understanding. As with all things technical, there is always a more complicated underlying base of knowledge. However for our purposes as photographers the simplistic methods are usually enough to get a general understanding and appreciation.
You can do some easy internet research for the best commercial and pro lenses, does not have to be 645, can be any format and any brand. Then find the resolving power of the lens at its optimal aperture. Does not matter what the aperture is, for this purpose. That will be a number of line pairs that the lens can resolve within a given distance.
Then consider the pixel pitch and we have to assume that the RAW file will be compiled to the same resolution as the pixel pitch. This is most likely not the case, but for the sake of understanding the concept, lets make that assumption.
Take the sensor pixels across the sensor and assume it is technically capable of resolving a perfect vertical line from top to bottom on every second column of pixels. This will fill the sensor with line pairs across.
We know that the 645z sensor has 8,256 pixels across. Divide by 2 equals to 4128 "line pairs". We know the width of the sensor is +/-43.8mm which will result in +/-94 line pairs per mm (not inch BTW). You will struggle to find a lens that can resolve more than 30 line pairs per mm.
Thus, there is a gap between what the best lenses can resolve versus what sensors can resolve. Perhaps the larger CoC is the important issue here instead of the pixels.
My apology if I dragged this out too much step by step.
---------- Post added 2021-12-30 at 05:26 PM ----------
Originally posted by Ian Stuart Forsyth
Your CoC is dependent on how much you stop down the lens, when you stop down the lens either on a cropped sensor like the K3III or using the 645z for the same amount of DOF you need different ƒ stops thus different CoC. If you are using the same DOF for the both formats then how much of the CoC occupies within final image will be the same. Now with the 645z because it has more pixels within the image for the same CoC the 645z will put more pixels within that CoC and in theory a better recording of how that CoC is being projected and may give you a little bit more detail ..
Now if both sensors share the same amount of pixels for the same DOF both will have the same amount of pixels contained within those 2 different CoC's
---------- Post added 12-30-2021 at 02:33 AM ----------
You also have to remember that CoC is not just one CoC striking the sensor but many of different sizes depending on the wavelength of the the light, so that really there is not a single point of light that will correspond to a patch of photo sites but rather an overlap of many that the sensor will be recording, if you want to record the best information you want as many photo sites recording this overlap as you can. If you can record exactly how each light point is being projected and how they overlap the you will capture the best that lens can project.
From my understanding Circle of Least Confusion is a better description of the concept, since there will always be some imperfection. My impression was that the diameter of the CoC does not change with aperture. The angle of the "cone" of light to the point of focus is just flatter with a smaller aperture, hence deeper DoF.
You are right there are an almost infinite numbers of CoC on the sensor/film representing everything in the image including the frequency range of "colors", some in focus other not. CoC also overlap each other, hence suggestion of a near infinite number of CoC.
Yet to understand the behaviors of matters such as this, it helps to isolate only one scenario at a time. Think about the behaviors of waves, where a single point is considered to map out the wave behavior. The same concept applies in this instance.
