Hi all,
I'm desperately looking for a -3.5 corrective lens (named "Optical Correction Lens" by Pentax) for the diopter of my Pentax 67II. The lens that is currently in my Pentax 67II's diopter is the standard one (-0.5), which only has a diopter adjustment range of +1.5 to -2.5. I need a diopter lens that allows adjustment between -3.0 to -3.5, so the standard diopter lens currently in my Pentax 67II diopter ring won't cut it, since it maxes out at -2.5. I've attached a page from the Pentax 67II manual regarding "Installing The Correction Lens," and it states that with the Pentax Diopter Correction Lenses the "diopter adjustment range can be changed from -5.5 to -1.5 (which I need) or -0.5 to +3.5 by changing the optical correction lens. Doing some simple math, that would mean that there was a Pentax correction lens of -3.5 for nearsighted people like me, as well as a +2.0 correction lens for farsighted people. It's this -3.5 Pentax diopter correction lens that I desperately need.
I've read on a forum that a Nikon F100 diopter/lenses should fit in nicely, so I bought said Nikon diopter with the -3.0 lens inside it, but found that it won't at all fit into the diopter ring of my Pentax 67II - it's far too loose. I've even removed the -3.0 lens from the Nikon F100 diopter to try to fit it into the Pentax diopter lens holder, but the Nikon -3.0 is too large to even fit inside that. I've also even tried sanding the -3.0 Nikon diopter lens down, but that didn't work either; the sanded bits scratched up the entire lens.
I asked my optometrist if he can fix me a -3.5 diopter lens, but he said that he doesn't do these types of things. I've even contacted Edmund Optics to see if they could perhaps make one for me, but I was told that they couldn't do it, but they could try for a whopping sum of $750, money that I, as a student, simply don't have.
I'm so frustrated over this because I've had this Pentax 67II for over a year now, but I can't use it unless use my glasses, which I
really hate using when composing my shots.
That said, short of getting laser eye surgery, does anyone know where I can get the -3.5 corrective diopter lens (or even a -3.0 diopter lens) for my Pentax 67II? Can anyone else please help me with this or offer any suggestions?
Any help or guidance would be very much appreciated.
