Originally posted by ron6771 Today I received a Pentacon 6 to Pentax 645 adapter. I bayoneted it into my Pentax 645Z camera body. When I press the lens release button and twist counter clockwise to remove the adapter, it will not move. I pressed the release button as deep as it goes, and gave a fair amount of force to the adapter, to no avail. Any suggestions on what can be done? This is upsetting.
This can be a major setback. I always test adapters new to me on some other adapter like a teleconverter or extension ring. Anyhow you are in the deep now and need to find a way out, not hear some smarts about woulda-coulda-shoulda.
It sounds as if the locking pin from the camera is pinched and cannot release. On the K mount the locking pin is on the front face of the flange, on the 645 and 6x7 the locking pin is hidden within the flange adge (female side). Most likely on a spring release. Meaning you press the release button, which pulls on a spring mechanism that pulls on the locking pin.
Being hidden within the female side of the flange makes it almost impossible to reach from the adapter side and your only obvious option would be to wiggle the adapter while holding the release button in all the time.
On the k mount the locking pin is a pin locking into a tiny hole on the lens. The 645 and 6x7 appears to be rather a stop behind one of the flange edges to prevent the lens/adapter from rotating counter clockwise. That would indicate that the adapter's flange edge protrusion is a fraction too 'wide' or long. Just enough to engage the lock mechanism but too tight to release it.
So incorporate as part of the wiggling, rotating the adapter clockwise hoping you can makeup the out-of-tolerance dimension with gentle wiggling.
Make sure you keep the release button pressed in while you do this, just in case the flange edge causing the problem is not wedging the lock more. So keeping the button pressed will cause the lock to release as soon as the adapter's flange retreats a bit.
More than this I can't help, and if this fails I suggest to get it to a technician that can pull more tricks or dismantle the adapter without damage to the camera.
Best of luck, and sorry to hear this issue had trapped you.
