Originally posted by TDvN57 My initial impression was that the FA200 does not pair very well with the TC1.4. I did some more tests recently and I have to retract that. It is not a perfect match for pixel peeping, but with a little tweaking in post production you can recover the sharpness to a high level. Thus I would recommend the pairing of the FA200 and the 1.4TC. I also recommend that you test for the ideal aperture with the combo, because the combo drops sharpness fairly quickly once you stop down the lens. I find it to be sharpest at wide open, 5.6 and Bokeh very pleasing.
I don't like the 2.0TC on any of the lenses as the loss of quality is too much, in my opinion.
On a side note, you can always consider some longer 6x7 lenses, that will be manual focus (same as with the 1.4TC) and if you do some research on the reviews, you may find some pleasant surprises.
Thanks very much for your advice. I'm not sure why the optical quality would degrade as you stopped down the lens, but I've read that from several sources. I guess that keeping the FA200/F4 wide open at F4 would give an equivalent F5.6 with the 1.4X, so you'd have a reasonable depth of field for distant subjects anyway.
The 6x7 lenses would be larger and heavier in general than the 645 lenses, no? If I had a Pentax 67 body it would be different (maybe someday!), but for now I think I'd stick to the 645 lenses. If I didn't do the 1.4X converter, I might go for the FA300/5.6 some day - but I just don't relish the idea of carrying that around in my backpack.
Thanks - Richard.
---------- Post added 02-15-22 at 08:42 PM ----------
Originally posted by RICHARD L. I surmise with what Theuns says : while it is possible to use the 1.4X TC with the FA 200 mm f/4 with some success, they are not "the best of friends" in my experience. Check the "Lens Reviews" section for the FA 200 mm as well as for the Teleconverters.
I would suggest you check for a "like-new" used 645 FA 150-300 mm f/5.6 zoom lens instead. This is a "sweet lens" when used starting at f/8. It sells for peanuts on eBay (probably because people don't realize what a treasure it is). Two examples below at 150 mm and 300 mm :
As for the 645 2X TC, my experience with the one I have has been "dismal", the beast does not perform acceptably with any lenses I tried it with. The 1.4X is not too bad but the 2X is to be avoided IMO.
Thanks very much for your comments. I did read the review sections before posting (I usually do), but if I still have some uncertainty then I go ahead and ask. On the FA150-300, your picture examples look great. My idea, though, was that I would carry the FA200 in my bag, and the small 1.4X converter, and this would be lighter than carrying both the FA200 and the FA300/5.6 (I don't have the FA300, I'd have to buy it). However, perhaps you are advising to leave the FA200 at home and just carry the FA150-300? That's an idea. On the other hand, the FA200 is rather compact, as is the converter, so size and weight might be an advantage for that combination.
