Originally posted by desertscape The general requirement of stopping down to f/8 or 11 when shifting doesn't mean that you cannot use smaller stops like f/22 and f/32. They work fine with this lens as well.
This lens was designed to be used off axis and is the reason why so many more lens elements are used in it, than in the regular 75mm.
Interesting anathema to the way Canon's TS-E lenses work (specifically the 24mm f3.5L, in the landscape context), where the function of extending depth of field is one accomplished using
tilt and not aperture, nothwithstanding that any amount of shift can be added in. Effectively, an Av of f5.6 can be used with a calculated tilt value (mathematical, in degrees, or visually by field-approximation) to extend the DofF from near to far in one distinct 'peg'. This is the same methodology with Nikon's tilt-shift offerings. I have always been of the opinion that the Pentax 67 system is hobbled by the absence of a lens that offers not just shift — which is very limited in its application, but shift and tilt also, to greatly expand the application possibilities.
How is the 67 75mm affected by diffraction at f22? When the lens is shifted, is the TTL meter able to accommodate an accurate reading (as the P67 does not have an AEL to lock the meter reading
before shifting)?
The other thing that perplexes me in this thread is that a lens hood interferes with the shift function? How, why or when does this interference occur if the hood moves with the lens (as a fixed accessory)?
