Originally posted by leonine Thanks Sandy. Lovely portraits. Thanks for sharing.
I will pick up the 105mm to pair with the Pentax 67 that I wish to get just to get started with film photography again. For 645Z, I guess the 90mm is very good. And so is the MF 150mm f/3.5 that I own.
I do not shoot Pentax digital in MF but in terms of performance and look, I've shot 67 glass on 645 (645Nii mostly) format for a good while, such that I don't own any native 645 glass for years now; I only adapt 67 lenses. That's mostly for consolidation of kit because I'm a 67 shooter first. But to that end, it's never felt like a compromise.
The 67 105 will obviously (as Sandy and Edmonds explain above) never realize it's full performance (the kind that led it to be "legendary") on 645 film or digital, but I use it fairly often and it works extremely well. A couple examples shown below. You can peruse the full album for this wedding if you like, which has a nearly 50/50 mix of coverage (in addition to B&W on 35mm at the beginning and end portions) done with both 645 and 6x7, all using the 67 glass.
Full album link is here:
Wade & Becky's Wedding, July 23rd 2016 | Flickr
(note to avoid confusion: the images below and those at this wedding link above are in my two
different Flickr accounts.)
The 105 is quite tight on 645 but works well for portrait indeed (2nd image below)... But in it's place I use the 67 90/2.8 far more often (on the 645nii), and in situations like this will pair it and the 45/4 on the 645, then the 105mm and 75mm on the 67 and/or 67ii. Makes for similar coverage and I generally move to 645 when the pace is quicker (for obvious reason). Incidentally, that 67 45/4 lnes is actually one of my favorites on 645 format, providing a look that is *somewhat* akin to the FA31 on Pentax 135 format ( shown in the last image with cinnamon rolls). All this to say, 67 glass works more than admirably on the 645 format, but the 105/24 used as such is not *really* the 105 everyone knows/loves.
Just thought I'd share all this for reference/perspective.
Pentax 645Nii | 67 105/2.4 | Konica Centuria 400 Pro e.i. 200
(contrast the above with the 105/2.4 on 67, this outtake shot with the nearly-large-format look for which the 105 is loved, simply can't be realized on 645...)
Pentax 67 | SMC 67 105/2.4 | Konica Centuria 400 Pro e.i. 200
Pentax 67II | SMC Takumar 105/2.4 | Provia 400F (RHPIII) @400
(just another showing the striking separation it can get with full body framing - this was a self-timer self-shot test and was "scanned" with a Ricoh GRIII, but that's a different story/topic)
(and here are a couple examples of the 67 45/4 on 645 format...)
Pentax 645Nii | 45/4.0 | HP5 Plus +1
Sorry for the blast of images, but I thought they could be helpful. Cheers all.
