we me and rafcamera.see other new thread by me are coming near to the truth. 1. i must first have a feelling of perfect sharpness at 7.7km little church and 200m tv-tower. no i will not judge the needle but the house up there about the same size like the chapel. will show when i have best possible sharpness using perfect zeiss 200/3.5 scale checked. and other lenses and system. one is for both MF and FF/APS-.C with changing heads. old novoflex A-tube focus-fotsniper design. can go beyond infinity. p6-bellows attached. can also shoot with novoflex B and c-systems 400/5.6 triplet very sharp and 600/8 less sharp. perfect wheather here after rain, only have now sunset images. also dont know if its jpg-unsharpness have raw. no deadjusted rafcamera adapter used but K+F comfort. where is suspect nikon-version is not precise. other one: EF-EOS. will get newest Novoflex Nikon-combo P67-system. to nail the mistakes. will also test all my other FF -adapters. newest pixco ni-EF. have K+F comfort best for C/Y-EF. yes i found difference to others. the mentiones aps-c-shots not done with special P67-M68(P6)-adapter but K+F comfort.
measuring the adapter and calculating deviation i come to 1.12mm between needed register and measured adapter. that is really true since adapter cannot be mounted full 2 1/4 rotation., its going in only mayb 350. difference 1.mm!!! means when he changes that infinity may be reached with perfect lens.
helicoid is telling: 15.5m to infinity 3.5mm. 3.5 -1.12= 2.38mm.
dont know what is meant with the triangle. pls let me know. if 200m helicoid is moved from infinity by 2.38mm which distance is reached? pls add calculation.
read also my finding in new thread about rafcamera adapter. he also make one for macro 0.2-1m and biometar 120/2.8 for P67.
NB: with deadjusted adapter it is easily possible to judge defocussed P67 lenses on P6-camera.one will get near distances and target easier to judge., e.g. at 15,5m outside i have tiny Siemens letters. and when dark enough i can check distance with bosch zamo HQ-lasermeter only when EV is 7 and darker.
---------- Post added 09-25-22 at 08:24 PM ----------
Originally posted by photoptimist If the flange focal distance (lens-mount to film-plane distance) is off by ∆, then the image magnification when the lens is supposedly at ∞ will be m = ∆/f. The distance from the film plane l to the focus point on the subject would be f*(2 + m + 1/m).
For ∆ = 2 mm, I'd expect the 135 mm lens to focus at about 9.4 meters and the 200 mm lens to focus at about 20.4 meters.
For ∆ = 2.6 mm, I'd expect the 135 mm lens to focus at about 7.3 meters and the 200 mm lens to focus at about 15.8 meters.
So maybe the adapter is off by 2mm and the 200mm lens is off by an additional 0.6mm
Some complicating issues:
1. The exact distance of adjustment of the helicoid is not easy to calculate because it is a function of the lens design. With some true telephoto lens designs (used to make the lens and helicoid more compact), the helicoid moves less than would be expected compared to the thin lens formula.
2. It is really hard to judge the center of focus near infinity because the hyper-focal effect biases the depth of field toward infinity. Although some use a one-third / two-thirds split between the front and back depth of field that is only correct if the center of focus is exactly one half the hyper-focal distance. If the lens is set to the hyperfocal distance then everything from 1/2 the hyperfocal distance to infinity is "in focus." Compounding this issue is that atmospheric disturbances and haze make distant objects fuzzier than they should be. Stars at the zenith make a good "infinity" target but unless the lens can focus past infinity, it's hard to tell whether the non-zero size of the stars is caused by atmospheric effects, aberrations in the lens, or a lens that cannot get to infinity focus.
Overall, it seems the adaptor is certainly damaged, defective, designed wrong. It's also possible that the camera body is not quite right, either.
i thought 135mm is more deadjusted.it not easy judging since 7.7km is too far.
will judge a nearer distance and tell helicoid difference 10.5 to infinity. maybe possible infinity-judging by comparing 135mm lenses. i also have very sharp MUP 150 blue(not better than standard only different shape of one blade-bent blade) and vacuum-back can even use 220 beside 70mm. can use technical pan. but then must shoot also with Kiev 60 or best would be p67 with vacuum-mag.orHBV conversion with vacuum mag.
---------- Post added 09-25-22 at 08:43 PM ----------
when judging from lens-helicoid-difference 3.5mm minus 1.12 too thick adapter= 2.38mm lens-deviation i am getting 86m. but can only judge when having perfect p67-lens.
can judge p67 lenses on K+F comfort but need sharp target at 100m. i can calculate with gps-map-ruler. thats what i used to measure distances in town.
i will find such a target. maybe best waiting for Novoflex-P67 universal adapter 300 euro complete. sooner or later will also get nikon DSRL D5200.
