12-24-2022, 08:48 AM   #1
NEED HELP with Setting up my 645Z
A few things I cant seem to get to save in camera:
1- I turn the power on and I set the date and time:
I shut the camera off and it does NOT sane the date and time. I have done this several times
2- When I turn the camera on I want to see an image in the rear LCD:
I only the display and cant see the area I want to shoot. I checked the menus and cant seem to locate whatever it is to get rid of the Display screen so I can see what I am shooting through the REAR screen
Thats it so far. I appreciate whatever help I can get so I can get my Z setup. Thank you Dennis
12-24-2022, 09:34 AM   #2
I have a cold right now with limited ability to remember much, but there are two sources that you need: (a) The most excellent 645z review done by the owner of this website, and available somewhere on this website, and (b) the exhaustive two booklets that should have come with your camera -- the Operating Manual and the Menu Reference. Perhaps they can be obtained from B&H or Pentax.
12-24-2022, 09:44 AM   #3
I did figure out the Screen display.
Now for the Date and time. That should be simple enough. Ty for your suggestions
12-24-2022, 10:04 AM - 1 Like   #4
Charge the DLI90 fully; it helps to have a spare. Leave it in the camera for a couple days at least; there is an internal storage device (super capacitor or other battery, I can't remember) that has to charge up, and it gets its juice from the removable battery. Probably the camera sat for months without a charged battery.
---------- Post added 12-24-22 at 12:06 PM ----------
Way back months ago, you asked the same question about 645Z settings. See this thread:
Is there a Tutorial for setting up the 645Z - PentaxForums.com
12-24-2022, 11:34 AM   #5
Sent you a PM Thank you again. Happy Holidays
12-24-2022, 11:41 AM   #6
Medex's Avatar
If date is not saved the internal battery could be dead or not able to charge.
Shooting with rear screen is possible in Live view mode.
12-24-2022, 12:39 PM   #7
Thank you but Professor Buzz got me to it. Thank you for the post.
12-24-2022, 12:43 PM   #8
TDvN57's Avatar
Asking for the date and time is super annoying. You can try to reset the internal clock by switching the camera on and removing the battery. Let it sit for 12 to 24 hrs while switched on without a battery. Switch off and insert a fully charged battery and switch on, enter the date and time and you should be good to go.
I started to experience this issue after using a genetic brand battery. After a reset and I use only Pentax branded batteries I don't have the problem.
Hope it works for you.
12-24-2022, 01:23 PM   #9
I got it working. TY
12-24-2022, 04:16 PM   #10
I also only use Pentax brand batteries.
645d, 645z, battery, camera, cant, charge, date, display, medium format, months, screen, time
Is there a Tutorial for setting up the 645Z rollsman4 Pentax Medium Format 11 02-06-2022 05:14 AM
Need help setting up Pentax K-50 please!!! Jameson41 Troubleshooting and Beginner Help 24 09-07-2018 08:10 AM
Need help setting up wifi router with new modem r0ckstarr General Talk 10 09-05-2015 09:41 PM
Need help setting up backup HDs Jools Digital Processing, Software, and Printing 7 01-11-2011 11:49 PM
Need help setting up film>digital B&W comparison FHPhotographer Film SLRs and Compact Film Cameras 8 03-26-2010 11:08 PM
All times are GMT -7. The time now is 09:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
